Do they use OEM studs or an aftermarket stud, after alternative studs for my hubs.
Just visited Melbourne Trailers to get a quote for an axle with LR hubs. Nice bunch of blokes. They were quite chuffed when I told them that I had read in this forum about them being able to make up the hubs with 16mm studs for LR alloys. I am looking at starting the trailer in Sep. I will post pics as I go. Making a 7' x 4'6" box trailer with electric brakes. Any tips greatly appreciated
[SIGPIC]
2012 LR Defender 90 (BERT) Gone
2012 Husqvarna WR 300
2014 FPV F6 Gone
2005 D3 SE V8
2011 D4 V8
2016 Moto Guzzi California Audace.
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
Honestly - well this is my thoughts on this matter!
If you have the ability to competently and safely build an off road box trailer
Dont buy a poxy trailer parts axle on hacked out electric drums with imperial studs that almost fit
Just find one of the 653 million being wrecked disco 1s
Pilfer the rear axle for a carton then take the
stub axles - hubs discs & flanges - calipers - rear hardline and brake flex line
Build an axle from solid 45 or heavy wall SHS or tube with flanges that the stubs bolt to and then you get to run proper bearings with proper studs on proper hubs with hydraulic brakes
Youll save a packet (as long as you can cope with override hydraulic) and have a better end product
Steve
"their" products I assume will be ALKO or such like still stuck in the seventies with HJ holdens
The trailer "parts" industry is simply cheap and nasty - I guess that is what the market wants
It can be done better and more easily using components properly designed for the task - ie pilfer parts from fourbies
By the time you buy an ALKO 45mm axle a pair of 10" braked hubs then drill the hubs for the correct studs - buy studs and nuts you could have bought 4 rear axles and ended up with components that will outlast the trailer
Dont even get me started on what the trailer industry consider appropriate with regards to leaf spring packs
S
