Results 1 to 10 of 25
Thread: Caravans and Better Payloads
    Oct 2011
    Fremantle WA
    Having had a change of plans (got older) and sold the old greyhound coach RV, which could not only pull a combined trailer, junk and D2 mass of 4.5 tonnes, but also 1000 plus litres of water and my miscellaneious tools and toys, I'm starting to cull my collections of "I must take that" to cater for what will legally fit (weightwise) in a caravan for extended trips.
    From my limited to date research it appears that not many caravans (offroad or otherwise) cater for those who want to live in their vans for longer periods and want to take some of their lifestyle items with them. Not only are heavy considerations like extra water (clean and grey/black) for extended free camping limited, but the potential to carry heavier tools and playthings (dingies, outboards, motorbikes etc) appears to be quite restricted.
    Anyone know of caravan manufacturers who make provision for better payloads, even at the expense of less space and item luxuries? Apart from the occasionally advertised 2 room versions where you roll in your quads or dirt bikes for a quick weekend away, I can't believe no-one has addressed this market niche!!
    Kootingal
    Bushtraker will accommodate heavier weights but don't think they will lessen the lux side.
    They have been known to make up to 4.5 ton vans. They are heavy empty however
    Tassie/Perth
    Honestly it sounds like a 5th wheeler would be more down the line you are after. You can get dual cab or single cab utes that can tow them, and in some cases they actually weight less that the caravans.
    Add in the advantages of the weight being right above the rear axle, and you can set up a base camp and still have the advantage of a good 4WD and it's hard to understand why they aren't more popular.
    Chris
    Oct 2011
    Fremantle WA
    Quote Originally Posted by cewilson View Post
    Chris
    Good idea - SWAMBO likes them, but pretty hard to move with a D2a!
    Tassie/Perth
    True that!
    Although a dual cab conversion would look great
    Oct 2011
    Fremantle WA
    True that!
    Only problem with the dual cab/ute idea is the turntable / 5th whhel needs to be forward of the rear axle - not that much room to comply in a D2!!
    Tassie/Perth
    Seems like you've got yourself a conundrum then. Let us know how you get on with it.
    Chris
    East-South-East Girt-By-Sea
    1.20 MB
    Most 5th wheelers are too heavy for the majority of utes we have in this country although you see lots of them. The type being suggested here should actually be towed by something not less than a Ford F250, Dodge Ram, NPR Isuzu or Mitsubishi Canter etc.
    Jul 2009
    Quote Originally Posted by gavinwibrow View Post
    Actually the hitch for a Fifth wheeler needs to be behind the axle, not in front of it.
    If you are seriously considering a Fifth wheeler check out PUMA RV's their vans are made to Australian spec (most others are to wide if they have an awning fitted) and theirs tow pretty well with a Navara etc. Their boxes aren't that long compared to many others, how the make up the space is with massive slide outs.
    The other thing is they are very reasonably priced from what I have seen compared to many others sold here.
    They also sell some pretty impressive Slide on's as well.
    Terry
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    Gladstone
    If you want long term living then nothing smaller than 21' would suit.
    You want a van with a tare around 2500kg with GTM of 3500kg factor in 300lt of water and you are down to 700kg of payload. You still have another 50kg in gas and toilet water to account for as well.
    This is doable from the right caravan builder but you have to be very clear on what you want up front. Stick with the smaller specialist builders as these guys will build what you want and you tend to deal direct with the factory. Going via dealer on special build will only cause pain because dealers are bloody idiots who are only interested up to the time they get paid.
