Thread: bolt -on gearbox crossmember
    G'day,
    I am starting my 57 86" resto. I can dimly recall that some gearbox cross-members were bolted in place which makes gearbox removal easier.
    Mine is welded in.
    Any point in doing a mod to make it bolt-in? anyone have pics or guidance?
    Russ
    G'day,
    Mine is welded in.
    Russ
    Last edited by Lotz-A-Landies; 31st July 2012 at 03:56 PM. Reason: same topic, same member 2 forums - merged
    Narre Warren South
    How often do you intend taking the gearbox out once you've restored it ?
    If it was a high usage vehicle I could justify it but otherwise maybe keep the chassis original and overhaul the clutch/cgearbox so that it doesn't need to be taken out in the near future.
    A Series 3 I'm getting back on the road came with a removable crossmember that I could fit in. I'm in the process of overhauling the gearbox, it has a new clutch fitted so if I do a good job I shouldn't need to take it out for a long time.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    East-South-East Girt-By-Sea
    1.20 MB
    Some SIIB Forward Control and the SIII military cross-members were bolted on.
    It was a modification done by LROCS members in the early 1970s, however in those days our Series Landys were our daily drive.
    If you do the mod to a S1, you are de-valuing the vehicle to later restorers.
    Just out of interest, you say you have a 1957 86"???? I thought they were 88" in 1957!
    gearbox cross member
    Hello Russ, I fitted a removable gearbox cross member to my vehicle as the original was missing and so it wasn't much of a problem,but if your existing cross member is serviceable I don't think it's worth the effort as you still have to remove the floor to remove the bell housing bolts to engine block across the top and I think you'll find that the bell housing won't fit out under the chassis rails unless the vehicle is raised slightly ie. bell housing still bolted to the gearbox,but just my 2 bobs worth.
    Regards John
    Don't post the same question in two different places.
    It confuses people.
    1.20 MB
    Quote Originally Posted by JFD View Post
    Regards John
    The beauty of the removable cross member is that you don't have to remove the seat box to remove the gearbox.
    You can also remove the transfer box off the back of the gearbox and take it out underneath, without either having a removable cross-member or jacking up the car.
    Similarly you can then remove the gearbox by only lifting the floor panels, but you need to jack up the car to pull the bellhousing under the chassis side rails.
    thanks!
    Thanks for your help and advice.
    I'll leave the X-member as it is
    Sorry about the double post - just wasnt sure it would be best to put it!
    I'm fairly sure that the year is 57 but not 100%
    R
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    chassis number?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Mar 2009
    Near Geelong, Vic.
    I Did It!
    GB Crossmember Converted to Bolt-on
    My problem was the Holden 186 motor.
    It proved damn hard to marry up to the gear box ON THE GARAGE FLOOR! I needed a change of underwear when I considered doing it in situ.
    Not that hard- but I would do it differently next time i.e. I would copy what the factory did with military variants rather than cut into the chassis.
