Results 1 to 10 of 18
Thread: Coil Suspension
    Apr 2012
    brisbane
    Coil Suspension
    Hi, I,m new to this forum but having spent some time reading the various threads I am impressed with the knowledge that exists hear.
    I recently bought a Discovery 3 S TDV6 2007. It only had 57 000 Kms on the clock & I am amazed at how it rides and the way the new style of diesel engine performs. It runs smoothly, is very quiet & has unbelievable torque & acceleration. My previous experience with diesel 4wd's was in the 80's with Landcruisers & they are chalk & cheese when compared to the Discovery (stunning).
    My 4wd history started with a 1979 Series III swb Landrover. Great car for it's day, took me to many remote areas in central Aust (Taking plenty of spare axles of course). Then came a 1980 F100. Great for the beach but a bit wide for the bush. Next was a 1965 petrol swb Landcruiser softtop, bit of fun for a while (Nephew still owns it). Last 4wd before the Discovery was a 1982 RangeRover. This was an excellent vehicle. Had it for 19 years & it to us around Australia, through many trips through western QLD, NSW & northern SA. But it was time to move into the modern era, hence the Discovery. It is a big learning curve so it's great to see that this forum exists with all it's knowledge. I truly appreciate all the time that people put to share their knowledge & experience.
    I do have a few questions that I hope someone can help me with. Owning the S model I find that the coil suspension is too low. Does anyone have recommendations as to what type/brand of coils & struts work best to raise the suspension, & where to go to get them. I was hoping to raise it about 2 to 2 1/2 inches. Will lifting it this high cause any issues with increased wear of the CV joints. Do you need to change the struts to gain more travel or being independant suspension would it be wise to only allow standard extension because of increased CV joint angles.
    Thanks.
    Murray
    Toowoomba
    Hi Murray
    I have a coiler fitted with King Spring coil suspension. There are quite a few posts on the subject if you do a search If you look back at a few of my older posts you will also find information on coil spring suspension.
    There are a few manufacturers doing springs for the S coilers and a few members on site have them fitted
    I went with King Springs as at the time they had a better choice in rating as I required heavy duty rears for towing. The King Spring lift is quoted as 50mm which I believe is the legal max, forum members better versed will correct me if I am wrong. My actual lift was from memory around 65mm.
    They were fitted to the original struts, have been on for around 70,000 ks and have posed no problems with CVs. (See past post of mine showing axle angles)
    At a 2010 Land Rover off road training day I had no trouble matching the air suspension vehicles on the courses set. Mind you I do not think it was that extreme. I may have also had a small advantage with over 45 years in 4x4s and payed to do it each day as part of my job in forestry.
    Howard
    Apr 2012
    brisbane
    Thanks Howard for the reply.
    I have trouble finding things by searching on this site, might have to try the google search.
    It sounds like I am trying to do the same as you have for I to have a heavy camper so need heavy duty rear springs. Nice to know that the standard struts are working out fine, saves some dollars since they are only 60 00Kms old.
    Noticed the front bar. What type of bar is it & does it maintain the original bumper
    Thanks again,
    Murray
    Toowoomba
    Its the Land Rover bar. Good light weight bar to hang a couple of lights off and deflect pigeons but you would not want to hit a roo.
    The post that may give you useful info I posted 19th Sept 2009. The thread was called "Air suspension question" I could not link it to this page but it may google up or click on my avatar and bring up my posts and follow the dates back.
    Picture of Bar and vehicle at the 2010 Land Rover day near Toowoomba.
    Howard
    Dandenong Ranges - Victoria
    I went with (the matched set) of Dobinsons struts and springs in my D3 'S'.
    You get 50mm+ of lift over the standard suspension and the spring rate is increased over the standard coils. The ride will be a harsher than standard and the step up into the cabin is obviously a little higher.
    With the lift you now have a useful off-road vehicle although not quite to the air-sprung D3/D4 standard. A little care with line and approach/departure angles and you can go most places (becomes a tyre limit really).
    I tow a 1400+ KG van with no issues.
    Might be worth giving them a call (they are in QLD) and discussing the spring rates for your specific requirements.
    Dobinsons Spring & Suspension
    Mar 2010
    I also went with the dobinsons matched set. Extremely happy with them, slightly firmer ride, but the extra 50mm is really noticable once you leave the bitumen. I would highly recommend.
    Apr 2012
    brisbane
    I had a look at your old thread Horward. Very interesting reading, gives me confidence that the increased height won't affect the CV's. I think I'll talk to King springs & Dobinson's. Thanks four the heads up about Dobinsons you guy's.
    Toowoomba
    4WD ONE sell Dobinsons. I had them fitted to my 2005 Disco 3 TDV6 S and they have been great. Full spring and shocky replacement with longer shocks to match the springs. I got my posted to me for under a $1000 and the local suspension shop fitted it for $150. I tow a 1800kg Exodus 11 and have no droop at all with 180kg ball weight.
    Heathcote Junction
    Coil Spring Lift & bigger Tyres
    To resurrect an old thread.
    Will 275 x 65 x 18 tyres fit with out rubbing on a 50mm lift coil sprung D3.
    My thinking is that coil sprung D3's are pretty reasonably priced & there are now plenty of accessories.
    I would think a coil sprung D3 with the following would be a pretty good 4x4:
    50mm lift
    32 inch tyres
    ARB front & rear lockers
    rock sliders
    bull bar & winch
    No air suspension problems
    Would be at least as good as a Defender with same & probably just as reliable with benefit of auto, airbags & more power.
    Chuck
    MY 24 Grenadier Trialmaster
    MY 03 D2a
    Ex D1, D2, D2a, D3, D4, Prado, D4, D5, MY 23 Defender
    73 series 3 109 Truck Cab Tray Body, 79 Series, 76 Series
    Oct 2007
    Brisbane West
    Quote Originally Posted by chuck View Post
    50mm lift
    32 inch tyres
    rock sliders
    bull bar & winch
    No mate because it doesnt matter how we cut it the fender will have more tyre on the ground and with those tyres pushing into the ground, with more inate balance with more clearance than a coil sprung d3. Having said that it would be a very nice tourer and solid offroader is my bet.
