If the bar just uses the existing 6 factory bolt holes on the chassis (4 x vertical for bumper bar and 2 x horizontal for tie-downs) then there is an excellent chance that it will fit. The photo in your link appears to attach only at those 6 points, but it is difficult to be sure just from that image.
The main "gotcha" is likely to be air conditioning. Because your County has factory air conditioning the radiator grill sticks out further than on a County that doesn't have factory air, leaving less room for your winch. Also, you may have to drill out the two holes for the horizontal mounts because (I think) the County had a slightly larger horizontal bolt than the Puma. Half inch vs 10mm IIRC.
I had a Rovacraft tubular winch bar on my 1985 County (no factory aircon) that I later installed on my 2010 Defender. The Rovacraft bar fit perfectly on both models.
