Results 1 to 10 of 11
Thread: dual circuit brake master cylinder s2a 1965 109....
    Apr 2012
    Palm Beach QLD
    gidday landy bretherin
    just arsekin for some advise ona dual circuit master cylinder brake system with a brake booster conversion
    i have posted this question before inna different area and lotzalandies surgested a county transplant would do the job which was greatly appreciated.
    i am haveing trouble obtaining the complete county parts
    this is the make up of my bee love vid
    series 2a 1965 109 2 door s/wag
    ford 250 iron head cross flow
    defender front discs (tbc)
    drum rear(had it re built)
    brake booster (is there mounted not connected)
    hasa s2a/s3front end (tbc) as in inner and outer guards / headlights
    donaldson air cleaner type set up (tbc)
    thought a area with s2 / s2a as a heading might offer up some ovfa ideas
    mucha preciated
    cheers coopers
    ......no animals armed ... trees chopdead .... spellung checked yoused....
    Apr 2012
    Palm Beach QLD
    dual circuit m/cyl progress
    hello landy bretherin
    well after takin lotzalandies advice....
    " gotts tagitta county/ defender assembly."
    the conversion has progressed.... mooovin in forwardly dierections.
    ole mate up at forrest glen...umm b o r ...good advice, service and price.
    gotta new m/cyl., booster and near new pedal box.
    now jus gotta git sum copper pipe pin stuff and fit ter up
    how hard could it bee ?
    coopers
    .....organukly recykilled stuff .....salt roojuiced.....100% shoogur free...
    Apr 2012
    Palm Beach QLD
    im Back
    how hard could it be to convert a single system brake master cylinder to a dual system?
    ****a **** ... just elongate the hole of the pedal box, bolt up the new stuffya bought then get some brake lines made up and a way you go.....
    defender brake pedal box bolt holes line up with the original ones !!!
    well whodda thunkin .. no elongating the mounting holes .. yeeharrr!!
    (with every high there's a LOW...)
    the top of the pedal box sits when mounted too high and too close to the guard
    therefore the defender brake booster is too big (booster approx 250mm diameter... edge of pedal box frame to top edge of mudguard 35mm... about the same to the top of the bonnet when closed)
    conversely there ain't no room then to fit master cylinder...
    not bloody happy jan
    so.........
    has any body out there have any ideas?
    id just love to here them
    ohmmmmm, ohmmmm, oohmmmm.... no... that **** isnt workin either
    coopers
    Aug 2010
    Western Australia
    What about a late series 3 master cylinder? They were dual circuit, that way you should be able to use the standard pedal assembly and it should clear bonnet and line up with the bulkhead mounts. You may need the top panel from the wing though as they have a larger cutout for clearance.
    JDNSW's Avatar
    The late Series 3 assembly is a bolt-in replacement, except that it will foul the panel between the footwell and the top of the mudguard. This was modified on the Series 3 (and is no longer just a flat sheet of metal) for just this purpose, to clear a dual master cylinder.
    You can fit the Series 3 panel , but the attachment on the mudguard is in the wrong place - either fit an additional bracket to the top of the mudguard to accommodate it, or, modify the panel to fit the existing bracket with some sort of spacer - it is out of sight.
    Apr 2012
    Palm Beach QLD
    hellos land bretherin
    fanks for the replies muchly appreciated
    ANDY D110 and John
    thats whot i was finkin...
    ima likin the idea of been able to keeps the series pedal
    anyways
    will be talkin to BOR who sold me the defender stuff tomorrow
    hopefully sort this out
    your info will be very helpfull
    quite frustrating at the moment
    oooohhhhmmmm , ooooohhhhmmm...this hippy shh.. stuff still aint workins
    coopers
    Mar 2012
    Porongurup Western Australia
    I also need a brake booster set up for my SIII 100" cause of the disc brakes, does anyone know where I could find a pedal box and booster in usable condition.
    Jul 2011
    Yarrawonga, Vic
    Early model Holden commodore booster and m/cyl fits a series 3 pedal box, although this is a S3 firewall I think it should also fit a Series 2 firewall
    Dont remember exact model but I built the Landy in about '87 so the commodore was earlier than that.
    you can configuire the master cyl for discs all round / or drums all round or discs front / drums rear by the addition / removal of a valve on the pipe port.
    only issue is the fluid reservoir dosent sit level but never found it a problem, and I had to chop the top of the guard to make it fit, (tinsnips) thats a really botch job of a bit of old tyre tube to protect the sharp edges and to stop the tyre splashing all the mud up there, as there is no inner guard on Series models like there is on a Defender.
    (btw its a Cleveland 302)
    East-South-East Girt-By-Sea
    1.20 MB
    This was modified on the suffix H SIIa where the six cylinder had the booster on the pedal box.
    Apr 2012
    Palm Beach QLD
    my dearly beloved was originally a six
    it has a cut out fingy on the guard
    it had a pbr ? remote booster on the guard
    though it wasnt connected
    is there a dual circuit master cylinder i could fit
    utilizing the existing booster ?
    coopers
