Results 1 to 10 of 13
Thread: Eas factory height settings
    mattg Guest
    Hi crew
    Can someone tell me what I should set the 4 different height settings at on eas speak top system?
    Cheers Matt
    Illawarra
    May 2008
    That article is sort-of correct...
    EAS height is measured from the centre of the wheel cap to the underside of the guard.
    So, if Standard height is measured at 470mm:
    • Low/Highway height is 25mm lower than Standard, so 445mm
    • Access height is 65mm lower than Standard, so 405mm
    • High height is 40mm above Standard, so 510mm
    This is for the front corners. Add another 10mm for the rear corners.
    Make a note of the potentiometer readings in EAS Unlock before you make any changes.
    Cheers, Paul.
    mattg Guest
    Thanks Paul
    The EAS king
    Bit late on the changes but was not to hefty as We just chose one of the heights and made them all the same . When I get it all working we will work through the heights.
    Now the wiring on the valve block is correct but when I tell it to turn the pump on and this is from empty it leaves the front pass side on the bump stops and just keeps pumping um the drivers rear side. The other 2 go up a bit. About half the back one. Matt
    Jul 2010
    Sydney/Balmain
    If trying to level the RR from an empty tank situation it is a good idea to;
    Start the engine and leave a door open and let the RR sit for a good ten minute.This will fill the air receiver to set point, shut the door and the EAS should find its mark pretty quickly.
    Do a search on EAS Calibration ---there's a lot of info. Also read through EAS Recalibration - LR procedure? (Post #5 for DIY calibration blocks) ...
    May 2008
    Matt, if you use EAS Unlock can you change the height of each corner individually using the up/down arrows on the tab with pic of the car? This will confirm that the correct solenoids are working.
    mattg Guest
    My issue is that the pump does not engage at all without turning it on manually. my issue is when running on manual or easunlock manual it just fills up the back 2 bags with nothing on the front.
    I think I have 3 issues here.
    1.EAS pressure switch, compressor not engaging full stop.
    2. EAS ECU playing up.
    3. EAS driver unit on the valve block
    does anyone have one or all of the above that I can borrow for diagnostic elimination?
    also open to other suggestions?
    Quote Originally Posted by RR P38 View Post
    Jul 2010
    Sydney/Balmain
    Are you in Sydney?
    I have a Hawkeye, we can take a look at whats going on if you are near by.
    mattg Guest
    Cheers but we are in port Macquarie.
