Thread: any ideas on my idea?
    Jan 2010
    tom price the pilbra, west aust
    am wondering about using denso tape around the drive shafts uni joints to keep dirt water mud etc out of em, havent done it yet just had the idea while using denso tape at work today, what about using it on fasteners etc under the car?
    Feb 2005
    i would just stick to a good maintenance program........i grease mine every 5000km or after an extended trip
    never had a UJ fail, have caught one starting to fail during greasing
    Desno tape is excellent stuff for its intended use... on stationary objects/structures... I reckon that the combination of flexing and centrifugal force would shatter the tape in very short order if used on a drive shaft/UJ.
    Ean Austral Guest
    The problem will come if you dont get the Denso tape neatly around the component, if there is any gap water will get in and the Denso will hold it in there and it will rust/corrode/fill with dirt etc without you being able to see it.. I have seen brand new spare hydrolic hose's not wrapped correctly and when they have gone to be used the fittings and threads have been rusty underneath the denso tape.
    Think as suggested, regular maintainence is your best bet.
    Cheers Ean
    Moruya Heads/Sth. Coast, NSW
    Quote Originally Posted by ade View Post
    What about a rubber gaitor like on a tractor power take-off, if you could water seal it both ends it would work, or like me grease your uni's after every off road trip, Regards Frank.
    WA
    I suspect that either the denso tape would fail due to flexing, or it would wear away the yoke.
    Glad wrap works well.
