Results 1 to 10 of 11
Thread: P38 keypad
    judigroves Guest
    P38 keypad
    Hi all I'm a newbie so pls be gentle. I recently bought a P38 and the keypad doesn't work and yes tried to replace the batteries but no go. I have tried Range Rover in melb but they said they can't get them as cars too old. Does anyone have any ideas.
    Jul 2010
    Sydney/Balmain
    Does the red light come on when you push the buttons?
    ^ x2
    Also check the resync procedure.
    Have a read here: newrremedies
    and here: Security and Alarm System Operation & Diagnosis on Range Rover 4.0/4.6/P38A
    Aug 2010
    Wodonga Victoria
    Hi Judi, nice to see you found the site, there is a wealth of info here and you will also come across "rangerover.net I think it is. I have also found Paul P38a very good to deal with, he is in Canberra and runs a part time business called Hard Range.com.
    Find yourself an independent garage that knows Range Rovers. You will find that most of the dealers are referred to as stealers.
    As to you key problem, pop the rubber push bit of the keypad and see if the little buttons are centred over the push controls or not. If not just push them back into position.
    Jim
    Oct 2007
    Williamstown, Victoria
    From memory, try putting the key into the ignition, then press the keyfob buttons, that should get it working again for you, provided the battery is ok.
    Oct 2010
    Carindale, Brisbane, Qld
    Welcome. Be sure to post more details about your car, like model year etc, as key fob sync method is different for later models.
    Now: 2005 L322 Vogue 4.4 M62TU (Black)
    Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
    Some years ago, mine stopped working. A switch had broken loose from the printed circuit board so I opened the fob up and resoldered it.
    judigroves Guest
    Quote Originally Posted by RR P38 View Post
    Do you mean the light on the fob or dash, pretty sure alarm is working cos it flashes but no the light doesn't come on the fob
    judigroves Guest
    Quote Originally Posted by glenhendry View Post
    Hi it's a 95 4.6 does that help
    judigroves Guest
    Question
    Quote Originally Posted by whisky_mac View Post
    Jim
    Hi Jim
    Have removed the cover over the battery and there is no metal contact should there be one?
