Results 1 to 10 of 32
Thread: Tires for the Defender
    Aug 2012
    Hi All , dont know if this has been covered but can anyone tell me the max tire width that will fit on the 110 without rubbing or messing with the steering lock , I have a set 0f 265/75R-16 Micky Thompsons ATZ 's in the shead . will they work ok ?
    Feb 2010
    Deloraine, TAS
    A search will show up a few relevant threads like this one Defender tyre sizes
    Simon
    95 Defender HCPU 130
    "Tires" don't fit in Australia but "tyres" do
    Wayne
    ​VK2VRC
    LowRange 116.76:1
    265-75-16s will fit fine on Defender alloys...
    And just a friendly hint...
    We're in Oz mate... They're Tyres
    After all, your 'fender isn't made of "AL-Oooooh-Min-Um"
    Aug 2012
    Potatos or Potatoes, I’m only interested if they fit not a grammar lesson, but thanks anyway.
    So I guess there shouldn’t be any problems with the rolling diameter being that the 235/75r16 are aprox 747mm OD & 265/75r 16 are aprox 808mm OD they should still fit in the guard. I’m also guessing that the Speedo will be out at the same time, can it be fixed via the ECU like other 4X4 brands.
    Im also guessing it will labour a little being a bigger diamiter .
    Spelling lesson actually Your grammar is quite good
    Firstly, the rolling diameter difference is negligible...
    You have your sizings wrong
    235-85-16 is 806mm
    265-75-16 is 804mm
    Secondly, the speedo is already out! A 255-85-16 sorts it
    And no it wont labour... But is likely to use a little more fuel as wider tyres= more drag...
    And most vehicle brands ??? and Speedo adjustable calibration via ECU. Not many.....
    If you know so much about all these other vehicles, how can it be you know so little about this one
    Aug 2012
    Spelling lesson actually Your grammer is quite good
    235-85-16 is 806mm
    265-75-16 is 804mm
    Ok your right just noticd the "tyres" are 85's, so shouldn't be a pronlem there .
    As for the ECU my F250 being an 05 model and cruiser both have been calibrated via thr ECU , just asuming that most are done in the same way. But thanks for your help , Its like a big jigsaw coming together .
    NSW far north coast
    Quote Originally Posted by Dockstrada View Post
    [snip]
    If you reckon Wayne and Mike are bad, just wait till Ron gets a sniff of it
    Aug 2012
    Quote Originally Posted by rick130 View Post
    Now im scared ,Sounds like he must be some sort of heavy , should I run for cover now ?
    May 2009
    West Gippsland - Victoria
    Spelling lesson actually Your grammer is quite good ...............................
    Tombie, Tombie, Tombie..............................sigh.
    Ron, Ron, RON. Where are you when we need you ?
    Deano
