Results 1 to 10 of 19
Thread: Cable Sizing for High Amperage Applications
    Aug 2009
    Brisbane, Sunshine Coast, Gladstone, QLD
    I am trying to size up the cabling for all of my electrics.
    Now these calculations are assuming absolute maximum load on the winches or the twin compressors.
    Chances are that they will not actually ever need to run at full load anyway.
    I am currently leaning towards running the 33 mm² cable for all aplications however I am a bit concerned on the possible voltage drop on the longer cable runs, however even at maximum load the rear winch would still bet getting 11.22 volts if you assume 12 volts from the battery.
    I have shown some larger cable sizing in red although I am not too sure if it is in fact needed or warranted.
    Anyone out there running rear winches etc and are able to share their setups and experiences.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Hi Chris, what sort of cable are we talking about here, and where did the voltage drop calcs come from?
    I have a 6 metre run of 35mm squared cable and their is no noticeable voltage drop over that length. Just went and measured it - 12.38 volts at the batteries up front, and 12.37 volts down the back. Not sure if this changes when loaded - maybe we need Drivesafe to chime in here.
    Not sure if I'd run 338 amps through it - mine is just to run a compressor, fridge and lighting - overkill for my application, but I had it lying around.
    Cheers - Gav
    Aug 2009
    Gav,
    Sounds like the same cable or very close.
    The voltage drop was through an online calculator, I can sit down and work it out manually to check the values.
    Mine is cable stamped with 32.15 mm2 (2BS) I purchased from Springers Solar.
    The 32 mm2 cable size is more than adequate for the dual battery charging, I am just unsure in regards to the winch cables.
    The standard winch cables are that size but are only around 600mm long.
    Western Victoria
    Quote Originally Posted by bacicat2000 View Post
    Cheers - Gav
    The cable has resistance.
    No current, no voltage drop.
    Once there is current, there is a voltage drop. V=IR
    What is the rated resistance of the cable?
    May 2006
    Woolgoolga
    i did the calcs years ago for my old rangie which had battereis in the back and obviously the winch up front, i had to run 70mm2 cable, was good for 400A at that distance all day long.
    Aug 2009
    Quote Originally Posted by Mick_Marsh View Post
    That is correct, hence the reasonable voltage drop through the 33 mm2 cable at 338 amps.
    A 6m length of 33 mm2 with no current draw has a resistance of 0.0031 ohms, meaning basically no voltage drop, at 100 amps voltage drop is 0.31v and at 200 amps it is 0.62v etc.
    These are generic calcs using the natural resistance of copper.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    The stuff I have is 0.554 ohms per Km...
    Your making my brain hurt Mick, I haven't had to work this stuff out since I was at trade school....
    Aug 2009
    Quote Originally Posted by Vern View Post
    Thanks,
    I went through the calcs tonight and I agree with the 70mm2 cable.
    50mm2 rated to 300A and voltage drop of 0.541v over 5.0m
    70mm2 rated to 400A and voltage drop of 0.372v over 5.0m
    My preference is to keep the voltage drop to below 0.5v so the 70mm2 cable will be the way to go.
    May 2006
    Woolgoolga
    Could always go conductors in parallel if you have plenty of the 33mm2 cable
    Dec 2011
    Hocking, Perth
    Quote Originally Posted by CJT View Post
    Thanks,
    I agree I did the calcs for my rear winch and came up with 70mm2; I'm using welding flex, nice and pliable, rear bar not quite finished yet but I intend to use an insulated post on the bar for the +ve then run 350Amp Anderson plug to get heavy power at the rear for jump starting on freeways and such (me's think a little safer).
