                                                4th September 2012, 08:41 AM
			ARB Bullbar winch install
					Hi All, Has anyone fitted a Avenger mako DTS 9.5 winch to a ARB Bar in a D3 (MINE 2005) if so did you have to rotate the free spooling end when mounting it vertically within the bar. I have noticed this has to be done with warn winches.
                                                4th September 2012, 02:27 PM
					ALign it to make it easiest to reach the winch.
                                                4th September 2012, 04:00 PM
					Havnt purchased it yet it gets good reviews. The only problem I see is that it only has three bolts holding that end on so you my not be able to get the end in a good position. Are there any other brands worthing trying other than warn as they are quite well priced and the use for me is not that hi.
                                                5th September 2012, 06:53 PM
                                                #4
					I went for the Tigerz 11 winch - 12,000lb with plasma rope - I don't expect (or hope) to use it much and as such the "price was right" for my use - it was about $700 from memory,
                                                5th September 2012, 08:24 PM
                                                #5
					Tigerz 11 winch - 12,000lb with plasma rope for me too. Still only used it once, but always hopeful. Details of install and turning the gearbox here.
 http://www.aulro.com/afvb/d3-d4-rrs/...ml#post1555463
                                                6th September 2012, 07:00 AM
                                                #6
					Thanks guys, I think the Avenger winch which only has three bolts holding the gear box on wont allow you to position it as a winch with eight or more bolts on the gear box. The Warn has to be rotated 144`deg to get the lever in a good position, so I may go with a VRS Winch which has 8 bolts holding the gear box on which are imported by Warn and have similar specs, the VRS 9000 for around $800- $900 for wire which I prefer,available from opposite lock and Ebay.
                                                6th September 2012, 07:52 AM
                                                #7
					I just installed a tigerz 11 12000lb in my Opposite Lock bar which is very similar to the ARB bar.
 I did look at the Avenger winches and OL install these in their bars so I'd be confident the gearbox rotates to a position where you can reach the freespool/clutch lever.
 Rotating the gearbox on the Tigerz took about 10 minutes.  95% of the time spent removing and fitting bolts.  Very easy to do.
                                                6th September 2012, 08:39 AM
                                                #8
					Thats good info makes me feel more confident about purchaseing any of these winches. What I can see between the top brands and the cheap chinese brands is in the gear ratio of the winch. With the top brands they have a lot lower gear ratio so the winch speed is faster but the current (amps) are higher. The gear box would have to be a lot stronger in lower ratio boxes. On the other hand if your not in a hurry or dont use your winch very often the higher ratio boxes would be ok. With the 12000lb winches seems all they do is put in a higher ratio gear box from what I have found out
