It depends how drunk your Defer was
 ChatterBox
						Subscriber
						ChatterBox
						SubscriberI'm guessing that my track rod isn't supposed to look like this.1995 Defender 130.
The red rod is there as a straight edge.
What I want to know , is it supposed to be perfectly straight or does it have a crank in it ?,( apart from the bends.)
Deano
Hey, it's better than mine was:
(And to answer your question - it's more a question of length than being exactly straight. Although the tie rod ends will work better if it's reasonably straight rather than cranked)
Looks like it's had a hard life - straightened no doubt by some bush mechanicing.
do yourself a favour and get a new one(new rod that is, not a new defender)
Whack that puppy straight, mark and remove the TREs and put a piece of water pipe over it then put the TRE's back.
Or else go buy a piece of DOM thick wall pipe, thread the ends, and put some heavy duty TREs in. Sorted.
You could do all that, but then a new one's only about $35 or thereabouts.
You could always buy a pre-bent one
but makes toe in adjustment a little fiddly
 ForumSage
						ForumSage
						 ChatterBox
						Subscriber
						ChatterBox
						SubscriberI kind of liked this solution, the question is how straight can I get it before sleeving ?
goingbush's set up looks ideal though. Is this the Maxidrive version ?
I thought this blokes solution was Ok too.
[ame="http://www.youtube.com/watch?v=EjFM9_wFOCg"]Land Rover - Track rod fix - Skibby nov. 2007 - YouTube[/ame]
Deano
