Definitely remove the inner spring - you could replace it with polyairs unless you are sure you will go full air, if so it will be a wasted expense...
For whatever irrational reason I have found that polys in the main stock spring (no inner spring) with an ally tray and Bilsteins rides like a dream compared with the twin spring set up.  And funnily enough, when you do load up it actually sags less than with the twin coils?
Air pressures depends on what you are doing...
My 130 with has 235/85 Bridgy MT and generally >75% on dirt roads;
If my load is light the front will have about 28psi and the rear maybe 30-32psi.
If heavy loaded Ill bump the rears up towards 38psi
On the black stuff if I have to do km Ill put them all up a fair bit.
Ive flogged a heap of different fourbies along dirt roads, despite the gutless engine a 130 with a well balanced suspension is amazingly quick - the wheelbase just soaks up the bigger ruts and rumbles that others are slowing for.
Steve
