8th September 2012, 04:41 PM
Cheap fix for old zips.
My Camp'o'matic is now 15 years old and a few things are starting to wear out.
I have been away for 6weeks and the zip on the main door flyscreen would not stay zipped at the bottom.
I did the normal squeeze the slider bit but it didn't work, so I thought that I am maybe up for a new zip at fabulous cost as the tent would have to be taken off the trailer.
As a last resort I looked on the internet and found the correct size slider. On a YKK zip the slider size in my case was stamped on the end of the slider and is 10C, c being for continuous nylon coil.
I ordered a couple from a place in the USA at $5 each and fitted one today, and the zip once again grabs and would not separate with a bit of tugging, so looks like it is OK for a while yet.
Regards Philip A
11th September 2012, 11:26 PM
Another quick fix so to speak is candle wax on the zips - it helps to prolong their life.
12th September 2012, 09:23 AM
Agree, I use Dri-Glide but when the channels on the slider get too deep you have to replace them..
Regards Philip A
9th October 2012, 11:44 AM
#4
If you still need them we can supply you complete zips, same ones we use on the Oztent. You`ll need to have them sewn in. PM Me...
Dan
