Results 1 to 6 of 6
Thread: Puma dash
    Mandurah. W.A.
    Puma dash
    Fitting a Mud Pod to the Puma, any tricks to removing the front dash section to run the cable.
    Maggsie
    Oct 2010
    Not really. Just undo the two screws that you see in the front facia and then gently pry out the sides. The faceplate "pops" out from four points on the front face and two from the top edge near the clock. Un plug all the connectors from the back and the entire facia, complete with radio, comes out. Easy as.
    Apr 2012
    Mosman Park
    To pry out the centre dash section without damaging anything, I used these plastic trim pullers from SuperCheap, SCA Door Trim Remover Set - 5 Piece - Supercheap Auto Australia
    I started at the bottom left, then bottom right, worked up both sides to the top.
    chook73 Guest
    While you do it extend the alarm antenna cable for better coverage. A quick search on here will give you a how to thread.
    My 2009 110 Puma thread Chooks Defender 110
    Sent from my iPad using fingers and thumbs
    Oct 2010
    Quote Originally Posted by chook73 View Post
    Any clues on the search word to use? That's a looong thread and a search with "antenna" only produced a hit on one post that was referring to the radio antenna and the sat phone antenna.
    chook73 Guest
    On my iPad so a quick GOOGLE search showed up
    Puma Remote Locking distance - FIXED!!!
    And
    Removing Puma Dash.
    And
    Not sure it these are the right ones though.
