Results 1 to 4 of 4
Thread: D2 Rear air suspension fail!
    Jacko Guest
    My d2 has a leaking air bag. I gave Triumph a call a second hand bag is $175 My local parts provider in Newy quoted me $330 for a new air bag and told me that second hand bags are unreliable and aren't worth goin there. Also a conversion kit to coils will cost me $350. I am unsure if i do the conversion myself how to shut down the compressor and what to do with the air lines. As i am setting off on family holiday in 3 weeks i am after a cost effective solution. What are your thoughts/experiences any advise welcome.
    darwin
    if you want to keep the air i have these.approx 30 min to replace each side.best to get 2 as the other wont be far away.
    Air Suspension Springs Rear RKB101200 x 2 Island 4x4 - Specialists in Land Rover and Range Rover Parts and accessories for all models. UK and worldwide mail order.
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Melbourne, AU
    Plenty of info on this site. It's an easy job so get a pair and replace both. Even with freight you will be better off buying from the UK.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
    Manly QLD
    Somewhere in the D2 section (or maybe its in Good Oil) there is a very good how-to that’s been written and posted by a member, even lists exactly what tools you need before you start, as mentioned it takes about 1hr to change both, did my ’99 about month ago – 13 yrs old and first time the suspension has been touched. I never had coils last that long.
    If you really want to go coils (don’t) then the conversion is easy, get a kit with the seats and all the bits, the lines can stay, as can the compressor and valves if you want to make it easy. Remove the fuse for the compressor and you’re good to go but there will be warning lights on the dash. There are 2 computer settings to change to make them happy and rid the dash of lights, Nanocom can do it or take it to the dealer.
