NOW THAT IS AN ENGINE!!!!
Anyone noticed the New Ford Ranger has the 5cyl Duratorq 3.2 litre engine
which may be an easy bolt in retrofit into the Puma.
In Ford Australia Ranger Wildtrack trim its 147kw@3000rpm & 470nm
which is a decent improvment over the 2.2.
Its on my to do list... if i ever get my hands on one cheap enough
Bell Auto Services has just done one into a 90(probobly the pic you have posted), same motor but out of a transit, there is some info on the defender2 forum somewhere, looks like a great swap.
 Wizard
						Wizard
						Yummy!!!
Defender2 - View topic - 3.2TDCI 200BHP into a Defender 90, It can be done!
Bit of light reading....
Is it true they nicknamed it the Puma because the engine produces the same performance as a 110 being towed by a cat in a harness?
Probably the same cat they tested the air gaps on.
Dobbo, I'm glad you said "cat in a harness" and not "pussy in a harness" otherwise my mind would be reeling by now
 ForumSage
						ForumSage
						That looks like a fun engine bay to work in ....
 ForumSage
						ForumSage
						Id be interested to see the Radiator, intercooler, A/C condenser set up and also the engine temps run if used in Oz in summer....
