There's a closed cell foam (possible Neoprene) sticky/non-sticky from Clark Rubber. Available in a variety of widths.
Looks very similar to the stuff I got from Paddocks.
 Fossicker
						Fossicker
						heeello landy bretherin
close cell sticky back/non sticky foam as a gasket...
say between the turrent and top of window frames etc
thats dust water and wind proof ,uv stable...
is there product /type that is true and tested ?
iva bortta roll of material to do my brake pedal box to fire wall seal
fort idda ask before i installs vis product...
coopers
 Master
						Master
Sounds a bit 'hi-tech', I used rubber from an old inner tube to make the pedal box gaskets.
http://www.aulro.com/afvb/other-powe...ies-3-a-9.html
The self adhesive foam will probably be a bit less fiddly to install though......
Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
 Fossicker
						Fossicker
						fanks for your replies
Ozdunc..
that materials sounds very similar to the product i borts
pvc/nit 6mm x 24mm x 12m is on the receipt
Gromit ...
thats sounds like the materials idda like to use ...
bang ups for a bit of recyclein meself
good thing about the roll of foam i fort ..
was u can install it in continous runs no little gaps..
only got motor bike tubes
was wantin to lift the turrent and replace the seal
also between the body panels where required
dont want to do it twice cause of wrong materials used
coopers
I sell rolls of 50mmx2mm (30'roll) sticky back foam tape vif you need some, I'll take a pic tomorrow and put it up as this bloody home computator is ted's brother for uploading.
cheers Ian
 Fossicker
						Fossicker
						fanks que Ian
appreciates the inputs
look forward to the pickkies ...
coopers
Ere ya go. I used it on Smeg between the tub and the roof, works a treat. $15.00 for a 30' roll if it suits you.
Cheers Ian
 Fossicker
						Fossicker
						fanks Ian
lookin good ...sold
errrr...umm sorry buts
how do we do the deal?
coopers
Maaaaaaaaate, gimme a call. 0755912523
1964, S2a SWB "Ralph"
1977, S3 SWB "Smeg" (Gone)
1996 D1 300tdi auto (Gone)
1973 Rangie Classic (Gone)
2012, 110 (Series 12) Puma "The Tardis"
1962 109" Tray Back "Ernie"
1998 D1 300tdi (Dizzy)
2017 Kawasaki Versys 1000
You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
 Fossicker
						Fossicker
						giddays Ian
im back
fanks
b givin u some contacts soooooon
cheers coopers
