Results 1 to 10 of 21
Thread: who's got the lowest km disco1/spec, maintenace work done
    Jan 2010
    tom price the pilbra, west aust
    thought it would be interesting to see.
    my 1995 epsom green metallic 300tdi 5sp has done genuine documented 259000kms with a full history from new, filters and oil every ten thousand kms, then every 5 thousand sinced I have owned it for 4 years.
    just put on a turners performance head and new radiator, it needed the rad, not the head, doin clutch this week.
    Feb 2012
    I have a white 1992, 2 door V8. It has 175,000 on the clock, One previous owner with all original books and records, it even has its removable centre console/sadle bag!
    I've spent about about 2k on it since I bought it earlier this year as the bearings and brakes needed replacing.
    Sep 2011
    I have a 97 with 147000km on it. As standard apart from oil changes and recent timing belt...
    Feb 2012
    Parkdale, Melbourne
    '95 TDI Disco with 151,000.
    Didn't realise when I purchased it that it had a small leak in a radiator hose, so before I got around to doing any servicing/checking it overheated. Now it has a new head gasket.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Apr 2010
    Hornsby NSW
    My 97 Disco has 126,000km and I've owned since new.
    3 x timing belt changes (maintenance)
    3 x serpentine and A/C belts.
    2 x idler pulley bearing
    1 x ZF box overhaul
    1 x drive plate.
    1 x radiator due to leak.
    transmission and oil cooler hose's replaced.
    2 x Crank seal (T-seal)
    Repairs to Alpine window surrounds under warranty.
    Mark
    Feb 2011
    Denmark Western Australia
    My 96 D1 duel fuel 3.9 has 110,000 I've had it 2 yrs it had a new clutch pp fitted, OME 2" lift when I brought it for $3000 , ive had to fix numerous water leaks from around fire wall, I've fitted cooper STT tyres, put in new brake pads , extra battery, head light wiring up grade,full leanth roof rack and front receiver hitch, repaired sagy roof liner, and replaced front and rear
    Lights, no real mechanical repairs as yet, fingers x. Gary
    Jan 2008
    Quote Originally Posted by Discomark View Post
    1 x ZF box overhaul
    1 x drive plate.
    Mark
    Why on earth have you had to do 3 timing belts?
    Gosnells
    - The drive plate is the give-a-way, - you've been doing burn-outs & donuts
    Apr 2010
    Hornsby NSW
    Quote Originally Posted by micko View Post
    1st one was done at 35k as the timing cover was removed while looking for a knocking noise that ended up being the drive plate but surprisingly sounded like the noise was coming from the front of the motor.
    Second one I did after another 40k just to be safe as it was 7 years old. And the last one not so long ago after the outer edge of the belt frayed and I could see the damage through the wading plug hole with a small globe.
    [ame=http://www.youtube.com/watch?v=LGoiye2IIMU]timing belt inspection Landrover 300TDI - YouTube[/ame]
    Mar 2011
    South Aust
    Ive got one of these but have never thought to check my timing belt with it.
    I use it to check the insides of my bikes. Remove spark plug and drop it down the hole. Great for checking piston tops and bores with out taking exhaust pipes off.
    Mini 5M 4 LED USB Waterproof Endoscope Borescope Snake Inspection Video Camera | eBay
