Results 1 to 10 of 11
Thread: Voltage from Alternator ?(what shuld it be?)
    Hamjam Guest
    I have a 1998 Defender 300TDI and I Would like to know what the voltage should be at the alternator as I ended up with 2 flat battery's.
    I think it might not working. I went to a local auto Electrician who said it was 13.5v at the alternator and 0.5v less at the Battery’s.
    He informed me that all is well.
    I thought that it should be 14.5 at the Alternator and at the battery.
    What should the reading be at the Alternator and Battery,
    I would like to here from other Defender owners what there voltage is ,
    Thank You
    James
    Crafers West South Australia
    Your alternator voltage depends on the current draw, engine revs, the temperature and the variability of the alternator regulator. Run the engine at 1500rpm or so with the lights off, test, then with the lights on. Voltage over 13.5V indicates battery is not discharging. 14+ V is what you would expect with a cool engine bay and no load. Don't expect much charging output at idle.
    Queensland
    Good point bee utey.
    James, with two low batteries, a small capacity alternator and the engine at idle, those reading may be fine.
    Sounds like an excuse for a good long drive and then see what the voltage is at the batteries.
    Hamjam Guest
    Thank you bee utey,
    I will give that a go.
    Sounds like very good advice.
    James
    Hamjam Guest
    Thanks Tim,
    I have been looking for a good excuse for a trip.
    James
    Feb 2012
    Parkdale, Melbourne
    I tested my 300TDI Disco voltage at idle no lights just a few days ago and it was over 14v. From memory about 14.5... Could check again tonight if you want an exact measurement.
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Melbourne, Australia
    Quote Originally Posted by Judo View Post
    My Nanocm says 14.5 - 14.6 Volts at idle.
    Hamjam Guest
    Thank you to all who gave me advice i have checked my alternator and it is now 14 volts, I don't know what happened but looks like it is back to normal. I will be keeping an eye on it.
    Thank you all very much.
    James
    defender mat Guest
    Check the Current.
    I have recently sorted out a long ongoing problem with my 300tdi charging circuit.
    I had my second battery going flat and needing to be maintained every month or two.
    I had good voltage at the alternator and batteries.
    I thought for a long time that it was my battery controller and looked into alternatives, but in the meantime I looked into the wiring and earthing.
    I checked the current at the batteries and noticed it was non existent.
    Short story - Finally found a replacement regulator, old one was worn COMPLETELY down, now all is amazing. Headlights bright, dash bright, cranking battery is full and strong.
    Now I will put some money aside for a new headlight switch as this one will fail with all that current.
    Queensland
    Quote Originally Posted by defender mat View Post
    Hi Mat and can I suggest you get one of my headlight upgrade kits instead of the switch.
    The kits take all the high current away from the headlight switch and you will never have to replace the switch again.
