Results 1 to 10 of 20
Thread: New Rock Sliders
    Karalee Qld
    New Rock Sliders
    My original side steps had expired. They always hung too low, were made of alloy and I was always going to change them at some point. That point came when I dinged the passenger one up quite nicely.
    After some research on this forum, this is what I decided. They are supplied by Mulgo in Sydney (Daniel), and I had Rijidij Off Road (Murray) in VIC fit them up for me. Two people I know (and a lot of people on this forum included) have used and trust - I am one of them. The Rock Sliders are Mulgo's standard but modified with the tube part bent down and some checker plate added - first photo tells the story. I have a few pics on the defender as well. They are solid as so should be great protection. Nigel
    SW of Geelong
    It took 2 hours to fit Nigel's new sliders. They are very well made and solid.
    They bolt up to the outriggers using existing holes and went on without any hassles. The only extra thing you have to do (on a Puma, not sure about other models) is drill out the rivnuts where the front mudflaps are bolted on. The mudflaps are held on with 6mm bolts in the rivnuts which wouldn't be strong enough for the sliders, the bolts for the sliders are 8mm , so you get rid of the rivnuts and use a washer and nyloc instead. The new bolts hold on the sliders as well as the mudflaps.
    The anodised ally checkerplate looks good against the black paint. Another great product from Mulgo.
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Jan 2012
    Sydney, Australia
    Quote Originally Posted by SVX37 View Post
    That looks real nice Nigel, good idea with the bent down bit which would actually assist getting in and out.
    I've noticed the matt decals / stickers on the side... did you get the Defender like that or added yourself? (I want some!)
    Jan 2012
    Melbourne, Victoria
    Quote Originally Posted by wannabeexplorer View Post
    The "matt decals" as you call them were a standard fitment item on the LR Defender 60th anniversary special edition "SVX" models. I'm not sure if or where you can get them, would be nice to find some though, I think they look great!
    Karalee Qld
    My wife is a little vertically challenged so this does help getting in and out. In addition, they do not hang down too far. The matt decals are standard on an SVX. There is a mob that sell something like that in Melbourne. A google search might be best.
    Central Coast NSW
    Hi Nigel,
    Very nice work mate, once again.
    I did sneak a look at them at the LR Expo.
    I actually ordered a set from Mulgo while I was there. Just the standard version but they suit me better.
    Nov 2007
    Gold coast
    Are these similar to the terrafirma ones?
    Central Coast NSW
    Hey Juddy,
    They look pretty much the same, but I think Mulgo's have them made locally to order, hence Nigel's custom jobby's.
    Nov 2007
    Gold coast
    Ah I see, I was researching the terrafirma ones, and thought they looked alike.
    The terrafirma ones are $ 500 rrp I think the mulga ones are 700 ish.
    It would be interesting to know what the difference is between the two types.
    I have not seen either so can't comment on the quality etc.
    chook73 Guest
    Quote Originally Posted by juddy View Post
    I haven't seen the tf ones but I have given the Mulgo ones a couple of tests and they have stood up well to both rock and tree.
    Sent from my iPhone using Thumbs
