Results 1 to 9 of 9
Thread: PC problem
    Sussex Inlet. N.S.W.
    PC problem
    Hi to the experts. Having arrived home after 10 days away I found my pc has gone funny. It was not used during this time but everything on it has changed. The screen resolution had changed from high to low but I was able to fix this. The games won't run and it says that my hardware accelerator is not on???? How do I overcome this. Also, and this may be the problem, looking at my display adapters I see two listed. Both the same . ATI RADEON 9550/X1050. and both show that they have problems. Firstly why do I have two of the same showing and how do I fix this problem. The games load under some soft thingy but are shrunken and won't run. Can someone help with a fix or do I need to call in a rech at exhorbitant rates? Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Ah! The vagaries of computers. Switched it on this morning and the stupid thing works. Whatever the problem, it resolved itself last night when the computer was turned off.
    Jim VK2MAD
    '17 Isuzu D-Max
    May 2008
    Albury Wodonga
    Quote Originally Posted by jx2mad View Post
    Ahhh and there in lies the solution with all things computing! Keep restarting till it spontaneously behaves. A good whack doesn't always go astray either
    Took me 4 restarts of an ultrasound machine computer last week before it behaved. No problems since!
    Sent from my Galaxy Nexus using Tapatalk 2
    Oct 2012
    A classic reboot will fix it moment.
    If it continues to be a problem
    1. Make sure you've applied all Windows updates
    2. Try the manufacturers website for latest graphics drivers
    Sep 2006
    Melb.
    As your running an ATI/Radeon card it is normal for you to see 2 x gfx cards.
    Quote Originally Posted by Dandevries View Post
    Or not.. I installed the latest driver for my Radeon graphics card today and ended up with an unreadable screen. I had to reboot in safe mode and roll back to the earlier driver.
    May 2003
    On The Road
    yes, but yours probably doesnt even have a fan,,,
    Probably not. It's my laptop. My desktop boot HDD died last night.
    Bangor, NSW
    I wouldn't mind taking a bet, that it was caused by fluff/dust in your graphics card fan. The restart probably dislodged it.
