Curious...
Initial thought was turbo but then you say that it spins up again once the engine has stopped. From your description, it sounds like a cooling fan but you'd be able to see those by the radiators.
* Power steering pump (I think it's electrical on the FL2)?
* Is there an emissions control system fitted? e.g. The D2 has a unit which pumps air into the exhaust manifold to help with the emissions.
What you can do is get a length of hose and use it like a stethoscope to help trace where the noise is coming from.
HTH
M
Hasn't caused a problem in 4 years and 142,000 kms
