I just pulled my factory AC out MY2005 Td5 Defender to replace with aftermarket A/C .
Amongst other things it just so happens I have my fan on ebay Landrover Defender A/C Blower motor (Smiths) 2005MY | eBay
One thing I noticed is the blower fan is quite stiff to spin by hand, specially compared to my new aftermarket evaporator fan.
Have a look at this thread
http://www.aulro.com/afvb/projects-t...110-wagon.html
and you will find a photo of my old evaporator, all that crud you see stuck in it is sucked up off the floor, same crud goes thru the fan & motor.
I think the increased load on the motor by gunged up bearings / seals could be whats blowing your resistors.
if your fan spins free then I cant imagine whats causing it unless the resistor isnt actually screwed inside the fan housing ( where it gets cooled)
