Hi Michael
Going through all this myself currently at 90k kms.
Took mine in for a wheel alignment recently and they would not do it as too much movement in the front lower control arm bushes.
Seems this is about the right time for them to wear out as car is very heavy and also they have a very tight turning circle which tortures the bits and pieces.
Bit of homework shows that best way is to replace the entire lower control arm (cost approx $350 each) which has all new bushes and a new ball joint, presumably of the latest upgrade variety. Total cost to remove and replace around $2k I would guess.
Interestingly, the local LR dealer did not seem interested in this solution only to press out and replace the bushes (which is a mongrel of a job apparently).
Suggest replace ARB bushes at same time and she should be good for another lap of the block.
					 You would have thought they might mention a fault like that. That said my rattle was really only noted when going over corrigations or speed humps to fast. The nice guys are a ringwood LD service place could not find it till they hit a speed hump as well. Quick and easy to fix.
