Results 1 to 10 of 11
Thread: Pool pump capacitor wiring
    St Helena,Melbourne
    4.28 MB
    Replacing the capacitor in my davey pump and although there is a wiring diagram on the pump, there are two wires (blue and light blue) but the digram just says blue for both ? Capacitor also doesnt have a pinout legend that i can see.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    May 2012
    Wannanup WA
    4.70 MB
    Either way around for such a capacitor, it does not matter which blue wire goes on which terminal.
    d@rk51d3 Guest
    Just don't go rubbing your fingers across the pins.
    St Helena,Melbourne
    4.28 MB
    Thanks, i know where the white wire goes but cant remember how the others went , white goes on front right and there was a cover on one of the other pins .
    1974 VW Kombi bus
    d@rk51d3 Guest
    So rubber cap goes on back right, and the 2 blues go on the left pins.(both lefts will be connected, but the joint may be hidden under the resin.)
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by d@rk51d3 View Post
    So rubber cap goes on back right, and the 2 blues go on the left pins.(they're both connected, but the joint may be hidden under the resin.)
    Excellent, thankyou both - much appreciated
    1974 VW Kombi bus
    d@rk51d3 Guest
    (waiting for the bang.......................)
    Gosnells
    St Helena,Melbourne
    4.28 MB
    Lol, you'll be waiting a while, pump is happily spinning and cleaning my pool as i type - i do have some electrical common sense .
    1974 VW Kombi bus
    d@rk51d3 Guest
    It's not your common sense I was worried about............ it's mine.
