Results 1 to 10 of 23
Thread: headlights wont come on
    May 2010
    Gisborne
    Hi all
    Don't know if you can help but here goes.
    My headlights were working yesterday and now they don't.
    I checked fuses near bottom of gear lever and found a blown fuse. I changed it but lights still don't come on. Parker lights & tail lights come on ok.
    Is there another fuse?
    I drive a td5 defender 110/ 2005
    Feb 2010
    Lights
    Mick It may be the light switch on the steering column. These are poorly made and prone to failure in particular if you run larger bulbs without fitting an upgrade using relays.
    Check to see whether your lights come on when you flash the hi-low lever.
    They cant be repaired and there are OEM (lucas) replacements which are the same as original and cheaper/ poor copies.
    I have read that you can save by using a Lucas from another model. prices vary considerable between 300TDi Td5 but the switches are very similar.
    May 2010
    Gisborne
    I actually tried a new one that I had bought a while back, and it didn't work.
    Might have to visit my auto elec again.
    Oct 2007
    Wantabadgery, N.S.W.
    If it does turn out to be a melted light switch, the fitting of a relay to avoid running all the power for the lights through the switch, will prevent the problem re-occuring. The other alternative is to fit a Traxide wiring upgrade.
    index7
    Don
    Geelong, VIC
    Quote Originally Posted by nod 130 View Post
    index7
    Don
    Yes, whatever your current problem turns out to be, definitely fit some relays if you haven't already done it.
    I fitted a Traxide kit to mine on the weekend and finally got to take it for a drive tonight.
    Apart from not having to worry about the switch burning out again, the light actually shines on the road now, and no longer cowers at the back of the reflectors too scared to come out
    Steve
    May 2010
    Gisborne
    I recently had an led light bar fitted and spotties rewired by auto elects and all new relays were put in. I have also previously replaced the indicator stalk.
    Might have to look at the new harness i think.
    May 2010
    Gisborne
    I think it might be my indicator stalk again as this morning the high beams only came on if you push it forward, but not back. I'm thinking that the stalk I replaced about a year ago has sustained meltdown prior to all the relays being put in. Why can't LR get something as simple as headlights right.
    Still love her though.
    Quote Originally Posted by Brad110 View Post
    The 300tdi has two types the later type is the same as the Td5
    All the difference between them is the plug. The switch is the same. But the older one is half the price of the newer style one. So last time I brought the older one and cut off the plug of the new one and put on the plug from the broken one. Same me about $70
    Ali
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    JDNSW's Avatar
    It can be either the combination switch or the main light switch. The headlights do not operate through a relay, and the switches are only just up to the job. Any increase in wattage of headlights without fitting relays means an imminent failure of one or both switches.
    The relays fitted with your extra lights almost certainly did not add relays for the original headlights.
    I would suggest that you find which switch is at fault, replace it, and add headlight relays as suggested.
    Mar 2010
    Mudgee-ish
    Quote Originally Posted by steveG View Post
    Steve
    X2.
