Results 1 to 4 of 4
Thread: Should have left well enough alone (EAS)?
    NSW Far South Coast
    My 2000 P38 has 200k kms on it and the only problem I've had with the EAS is it would drop its bum if left for a couple of days.
    As its only the rear and the auto level 'feature' is off, I've assumed it has to be a slight leak in the valve block, not the bags.
    So, armed with a goddies bag from Paul I decided to redo the o rings and redo the compressor. Preventive maintenance at its best.
    Well now it drops its bum in a couple of hours and the compressor probably needs to be replaced!
    Nothing looked bad inside the block and I 'filed' the plunger ends and replaced the diaphragm.
    The compressor. Well I managed to break one of the screws holding the end plate/bracket on, so now it only has two screws not three.
    Also, I was unable to get the con rod out of the pump so fitted the new seal 'in situ'. However, obviously I didn't get the clamp ring on fully as after operating well for a couple of minutes it 'failed to pump' and a re inspection showed the clamp and seal had come off!
    I've reinstalled the seal and it now pumps as it should, but for how long.
    So my questions are;
    what is the common link inside the block for just the rear bags themselves.
    do I repair the existing compressor by drilling out and bolting the end plate and buy a new cylinder/piston kit or
    upgrade to a larger compressor (Thomas 337?)
    Coogee, South of Fremantle, WA
    The alen head bolt holding the conrod on can be very tight so you need a good alen key with plenty of leverage to get it loose. Hopefully you did not leave any burrs on the seal ring or you will very soon get a nice score in the cylinder wall.
    To be honest I have had it with the original pump and if ever the need arises to fix or replace mine this is what I will buy and hopefully get to fit nicely...
    These pumps are being sold by American Air Ride companies and they are stating are better than Viair. 100% duty Cycle and an impressive blow.
    $30 off per $300 order Free shipping! DC12V Mini air compressor, Suspension air compressor! New design-in Pumps from Automobiles & Motorcycles on Aliexpress.com
    NSW Far South Coast
    I've found a bit of info on these.
    They do look good and only $150 ea, only $114 if you order 3 or more, delivered to OZ.
    I'm going to look at the measurements tomorrow and see if it could fit.
    May 2008
    Looks alot like the Viair compressor I bought a while back. No way will it fit in the existing EAS box, and there will be some mucking about to get air line adapters right.
    Trevor - I should be home on Sunday (assuming the Toyo I pick up on Saturday gets me back from Sydney ok) if you want to come over and measure up the Thomas and Viair compressors.
