After a quick look at mine, it looks as if you will need to swap the wiper positions to the locations where there is a black plug in your picture. Since the motor is on the left, and you are moving the wipers to the right, you will need to get a longer rack cable and outer pipe. Probably best from a wrecker.
You will need to disassemble a fair bit of the dash to get at them. The wheel boxes will be the same.
