                                                27th October 2012, 02:33 PM
			Flat Dog flexi fare fit up.
					I ordered a set of Flat Dog Flexi Fares from the UK.
 Part of fit up is to remove the stock flares ( just completed ).
 The front flares need to cut back to cover the gap between the inner guard and the mudguard.
 Problem is I am have trouble destroying my front flares.
 So the question is.....are the PUMA front flares particular to the PUMA or are they shared amongst other Defender models ?
 I hope to buy a second hand set to cut up, so I need to know what model's flares will fit.
 Oh, if any body has a set they want to sell......
                                                27th October 2012, 06:20 PM
					I recently purchased some flexi flares after putting wider wheels on. I'm also reluctant to cut the original front flares. I was wondering if you remove the old flares and used a wide strip of rubber, would that fill the gap? That's what I was planning on doing.  I have brush bars down the side as well. The flexi flares wont fit under them. So i probably wont fit the front flares. I didn't use the original screws, instead got some stainless bolts with allen key head. I packed out the rear with rubber washers I made with a punch set, as the recess for the screw/bolt is about 5-10mm of the body panel. Anyway, they look super tough.
 JC
                                                28th October 2012, 02:53 PM
					You could always try a wrecker, how are you going to feel about drilling holes in the panels though. I would think if you ever went back to the original flares the holes in your panels would be a bigger issue........
                                                28th October 2012, 03:43 PM
                                                #4
					Thanks for pointing that out.....
                                                28th October 2012, 04:09 PM
                                                #5
					No worries
