Originally Posted by
geodon
1st impression: were ear muffs an optional extra?
No, but it might have been an idea - however, I noted how quiet mine was after a partial strip to paint and reassemble with all body panels tight and all new rubber plugs etc.
There's a high frequency cricket chirping noise in top gear hi-ratio. Familiar to anyone?
No
I also get a "clank-clank-clank" as I cruise to a halt clutch in. This sounds like a uni inside the front diff but I did check each one carefully?
This suggests either it is stuck in four wheel drive, the handbrake is dragging, or both. May also indicate that some of the U-joints or splines are a bit worn. Also check that the U-joint flange bolts are not loose, both front and rear shafts.
MAN! Is 1st gear straight cut??
yes. so is reverse. Excessive noise may suggest worn components, but if you are not used to straight cut gears, it may not have anything wrong. As long as ithe noise is uniform, don't worry.
Apart from these, it drove & stopped well (good ole VH44!) but it sure made my split screen Kombis seem like winged gazelles!
Performance should be comparable to the kombis, may improve with the handbrake not dragging.
