6th November 2012, 08:59 PM
			1955 86' Seats
					I am about to make some front wood seat bases.bradonubique@gmail.com
                                                6th November 2012, 11:02 PM
					i am sure someone will get back to you soon if not i might be able to get a few photos next tie i am at the cave, as i have some more photos to take
                                                6th November 2012, 11:27 PM
					Brad,Advice on trim please.
				(REMLR 235/MVCA 9)  80"  -'49.(RUST), -'50 & '52. (53-parts)  88"  -57 s1, -'63 -s2a -GS x 2-"Horrie"-112-769, "Vet"-112-429(-Vietnam-PRE  1ATF '65 ) ('66, s2a-as UN CIVPOL), Hans '73- s3109"  '56 s1 x2
77- s3 van (gone) & '12- 110
                                                9th November 2012, 06:44 PM
                                                #4
			Series 1 seat frames
					I am going to make a few sets of bottom seat wooden frames. They will be of hardwood and same dimension as original with the tapered ends to fit into the seat locating slots.  I will then \brace mine with plywood to provide extra support for the cushion.bradonubique@gmail.com
                                                9th November 2012, 07:41 PM
                                                #5
					Forgotten where I got these , but from a public forum somewhere.
                                                9th November 2012, 09:53 PM
                                                #6
					if you are going to make the bottoms use a solid piece of ply underneath as well it makes it a lot more stronger and stops it from sagging
		You may not  post new threads
		You may not  post replies
		You may not  post attachments
		You may not  edit your posts
