Results 1 to 10 of 14
Thread: 4.6 to 3.9 ?
    Harry Safari Guest
    4.6 to 3.9 ?
    Ive only just bought a 97 RR hse Im pretty sure the block is cracked . Is the 4.6 really that prone to cracked block problems as all Ive been able to find are tales of woe. Are there any economic replacement options ie 3.9 for 4.6 changeover. Im not worried about power loss or performance just love the car but am finding no option other than the scrap heap. Thanks for any help.Harry
    Crafers West South Australia
    The 3.9's have a slightly shorter crank nose and no provision for a crank angle sensor. You could use a D2 4.0 engine but your best bet will always be to spend the pennies and replace all the liners with "top hat" (flanged) style ones.
    Feb 2010
    Townsville, QLD
    Think about what it will be like after you spend the money on it! If its good now it'll be great later!
    Every niggling thing you fix up is one thing you know for certain will last you another 5 or so years! And it's yours!
    Harry Safari Guest
    If the block is cracked?
    Harry Safari Guest
    Good advice, just hesitant about a known engine weakness.
    interesting commentary on why 94mm bore blocks may be prone to this problem... see post #6 in Rover V8 cracking block and all the theories around - Tools and Fabrication - LR4x4 - The Land Rover Forum That being said there are many many engines with hundreds of thousands of miles on them with no apparent problem
    Harry Safari Guest
    Thanks for that. If the tophat is the solution where should I start looking .Im in Newcastle.
    Feb 2010
    Townsville, QLD
    Any engine builder should be able to do it for you. Probably a good idea to find a good one, perhaps your local rover specialist?
    Jul 2010
    Lambs Valley - Hunter Valley, NSW
    Modern Motors, Dungog
    For the best advice talk to Modern Motors in Dungog for all things Land Rover.
    Go to
    About Modern Motors Dungog
    For some more detail
    Lee
    Jan 2012
    Bendigo
    I've been told under good authority, that if you don't get these motors hot, it rules out 95% of problems in regards to this.
