Running the stock battery, which I belief is 90 AH, plus a 90 AH Full River AGM.
That still leaves enough room to install a Ctek D250S and a Ctek Multi 7000 under the seat.
 Master
						Master
						I'm looking to fit a duel battery to my 90, i have a 120ah Fullriver from my last 4x4 but its to large to fit under the passengers seat.
A 100ah Lithium will fit with a little re-aranging of that part of the battery box
My question is what size in ah are members running?
At this stage i will only be running a 60lt fridge. We have the main fridge in the camper so the 60lt is only back up. I would also in time be looking at a winch for the truck.
In put would be much appreciated.
David
you can fit 2 x n70 sized batts under the seat.
you have to rotate them 90 degrees so they run across the car (if that makes sense)
Duel batteries; thems fightin' words.
 Master
						Master
						Thanks guys,
I have got a good price on the 100ah Lithium so i will get it & do some battery box adjusting to get it all to work. The Lithium is smaller than the N70 so should work well.
David
I have an Odyssey PC1700 and a 130Ah sealed unit (can't remember make but length and width are same as Ofyssey and about 15mm taller.
I also have room for an Albriet winch solenoid, a few relays, aux fuse box and aux earth bar.
Needless to say there's not much spare room in there and I need to make a new battery cage, but it all fits and works a treat!
Sent using Forum Runner
Regards,
Jon
 Master
						Master
						Benz
We are going to bring one in & test it first.
The price is around $500 without freight & only weighs 12Kg, my Fullriver weighs 36Kg & i have 3 of them.
I will update as we progress.
Sue nice article on your beast, looking forward to seeing it all setup!
David
