Results 1 to 10 of 12
Thread: Computor from USA
    Dec 2009
    Tyrendarra Vic (South West Vic )
    Computor from USA
    Has anybody bough a computor tower from America. Looked at an ASUS tower from Harvey Norman. $1988 Same basic unit from USA $1000- 1200 delivered. Slight difference in part no. (Aus) CM6870-AU...... ( US ) CM6870-US ......
    What are the pitfalls & any other problems for buying from overseas. Not sure if there 110 volt or 240 volt tho.
    As best as I can tell specifications are the same.
    Gary
    d@rk51d3 Guest
    My sister bought a laptop from the US. When it started playing up, they couldn't get it fixed because the US specced units had different components to the Aus market ones.
    The 110v could pose a problem, although most tower power supplies have a toggle at the back for changing the input voltage.
    Sep 2012
    NSW
    The US keyboard maybe configured with a very minor difference in some of the keys but it is no big deal -- and does not effect functionality
    Point to note nearly all PCs and the like are manufactured in Asia so try source from the Orient as a better buying option than the USA!
    St Helena,Melbourne
    4.28 MB
    Why would you look at hardly normal to buy a pc, go to your local chinese owned pc shop and get one built. 2K is way over the top for a pc these days unless you are buying an over priced Mac.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Dec 2009
    It was just an option. Was going to cost me about $900 to have my old girl rebuilt and upgraded. May get some quotes on having one built.
    Some spec's 2TB HDD, 16 GB Ram, Intel I7 & 2- 3 GB dedicated graphics. +++++++. Windows 7 or 8
    The old girl was 250GB HDD, 2 GB Ram, Intel Core 2 Duo ( about 2.3 Ghz) & Windows XP. Starting to have a few problems. So I think its time to upgrade.
    As for H/N usually get a pretty good deal there.
    Gary
    Sep 2012
    Adelaide Hills
    Msy
    All your problems solved
    Dec 2009
    Thanks for all the replys . Msy looks very interesting. Will see how I go
    Gary
    Jul 2008
    Ballarat, Victoria
    MSY can give a bit of a shock regarding customer service, IT guys aren't known for their small talk, but the value for money can't be beat so it is well worth it!
    Dec 2009
    So from what you all are saying MSY build good systems its just that customer servive leaves a bit to be desired
    Gary
    Sep 2012
    Adelaide Hills
    Quote Originally Posted by 33chinacars View Post
    Gary
    depends on the store, hell depends on the person you get.
    have a look at their website, find one you like then post it up here
