OK,
I understand your point of view. Yes it can be frustrating.
Now from my side, when you work on these things everyday, you get to learn how things fail & there cause.
The reason for changing the compressor, relay & fuse? Is because the compressor fails internally, fuse blows because the circuit gets hot, a relay getting hot means its life span has just decreased by X (how long is X you ask?) I can't tell you! I don't know, would you rather spend $30 on a part now. Rather than having to come back the next day to then have it replaced?
Hopefully the service advisor has explained that to you.
Cheers.
Sent from my iPad using Forum Runner
					 so I know that the compressor was functioning well until this time. Never overheated, never slow. Now "dead". Took in for service this morning and listed a few things I wanted assessed for their opinion.
