From land Rover.
Believe it it not they have a part number.
BDC710040
Or there is always plenty under the carpet of Range Rover classics. Where I can just imagine the builders of the car just throw them over their shoulder when making the car.
I finally decided to fit my "X-Trouser - Defender Door Lock Striker Plates" tonight but found that doors wouldn't close - they kept on hitting the striker plate.
I packed out the spacer with some bits of cardboard to if that would work and it seemed to be successful but I was a more permanent fix.
So, where can I get some extra shims from? Are they even called shims because I've not had much luck finding what I'm looking for?
Thanks in advance!
**Update: I found the part number. It is MWC3148 in case anyone else wants to know.
2012 Discovery 4 SDV6 HSE
2003 Discovery 2 TD5
2003 Defender Xtreme
1997 Discovery V8i
From land Rover.
BDC710040
95 300 Tdi Defender 90
99 300 Tdi Defender 110
92 Discovery 200tdi
50 Series 1 80
50 Series 1 80
www.reads4x4.com
I also had to pack my new drivers door striker out. I think I cut it out of a bit of aluminium. That said, the new x trouser strikers combined with a new genuine door latch, has made door closing a dream.
Don.
1997 Discovery V8i
I think you might be referring to part # MUC7890 - available from karcraft.com.au for about $4 each.
or here MUC7809 ANTI BURST STRIKER SPACER | Defender 1985>: Body/Fittings | shop | www.lrseries.com | L. R. Series
1998 Defender
2008 Madigan
2010 Cape York
2012 Beadell, Bombs and other Blasts
2014 Centreing the Simpson
VKS-737 mob 7669
That one shown in the above post is far thicker than an 'adjusting' shim. Mine are the same shape, but only about 1mm thick.
Don.
After a lot of looking I can confirm the part number is MWC3148 (and looks like this: MWC3148 DOOR STRIKER PACKING PLATE | Defender 1985>: Body/Fittings: Brackets/Fittings | shop | www.lrseries.com | L. R. Series)
In the end I decided that since these things cost a couple of quid each and I had no idea how many I'd actually need, I made ten out of plastic (using an old milk carton) and used them instead. They've done the job and cost nothing other than a few minutes with a Stanley knife.
1997 Discovery V8i
