Results 1 to 6 of 6
Thread: 130 Puma starter battery dead
    Adelaide SA
    Folks, my 2007 Defender starter battery has died so I need a replacement. I have looked at various forums and our search function but still a bit unclear on the best way to go. What do members recommend to replace the factory supplied battery?
    Boots
    Feb 2005
    your battery is five years old so you have had a pretty good run......
    a lot of guys seem to be buying CAT batteries, seem good value for money.......although replacing with the same sounds like a good idea as well considering 5 years service out of the first one
    Adelaide Hills - SA
    I've tried replacing my 110 battery with a yellow-top Optima Gell battery.
    It j..u..s..t.. fits but the earth terminal touches the lid and you have to mod the clamp a bit. And, you have to make up your own holding bracket as the bottom of the Optima's don't have the standard ridge that the OEM battery has.
    So there - if you are thinking of an Optima (which are great batteries) these are the 2 things you have to get past!
    David
    Nov 2012
    NEWCASTLE
    BATTERY
    HEY BLOKE YOU CANT GO PAST THE FACTORY OPPS caps lock again
    factory battery
    but you need to make sure that waht ever battery u use it needs to be the same cca and rc "reserve capacity" or higher!
    Aug 2009
    Kilkivan
    Puma Starter Battery
    Have a look at an Exide DIN 88.
    I have one in another car and it seems the same as the battery in my Puma.
    Adelaide Hills - SA
    Hey Boots - if you are going to get a DIN 88 battery shop around on price. I was after one for my Mercedes S class, and Mercedes quoted $600 for a genuine one, or $290 for an aftermarket one.
    Batteries online quoted me $220 for one.
    Got an identical one with a BESCO label on it for $150 at my local battery shop. They guy who runs the shop said Besco and Century are the same inside (made in the same factory), just different labelling!
