Results 1 to 9 of 9
Thread: Axle Question - Series 2a 88"
    Freosmiths Guest
    Hi All,
    Can anyone explain the extra "webbing" on this axle casing ?...certainly looks genuine i.e. not a later bodgy addition.
    Near Seven Hills, Sydney
    Normal. Some time during 2a production they strengthened the rear axle housings.
    schuy1 Guest
    It appears from about '62? for the LWB and then SWB's from 63? but anyway genuine factory fitment
    Cheers Scott
    Jul 2009
    S.E.Qld
    I believe strengthened axle casings were standard on Series 1s 88/109 with fully floating axles. About 1957. W
    Apr 2011
    Wandong,Victoria,Australia
    I'm no expert but both my 1960 SWB and my 1961 LWB have this.
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    Like many Landrover "features", I don't thnk this came in on a specific date or chassis number. It would have initially been optional, and later become standard, although Rover Australia may have adopted it as standard before the parent company did. Strengthened axles are fitted to most, but by no means all Series 2as I have seen, and the ages of the ones not so fitted do not seem to make sense! (of course you rarely know for sure what you are seeing is original)
    schuy1 Guest
    Yes I will agree with that. You never know if some later models bits been swapped over In my area there is a '60 SWB without the bracing and another SWB of same vintage with it front and rear although it being an army 1 could account for that
    Quote Originally Posted by schuy1 View Post
    Yes, as far as I know all army ones (except possibly some trial ones) definitely came with the bracing.
    axle lamination, intended to prevent housing bending if you hung up on it while fully loaded
