Thread: Codan 9323 Install
    Melrose Park NSW
    Codan 9323 Install
    Finally got time to install the Codan 9232 which I purchased from Trog. Bushie and ShortyNSW gave me a hand to mount the autotune on the spare wheel carrier and I mounted the radio.
    This unit is a far cry from my old Wagner unit I had in the Defender which has seen better days. On our last trip out the Anne Beadell and the 250 to 300 mile centre line of fire pegs, my attempts to contact VKS 737 was usually met with "Can you repeat your call sign please" or "you sound off channel". Others that heard me trying to log in at skeds said it sounded like Alvin and the Chipmunks.
    The mount that came with the unit did not fit so a piece of plate steel was welded to the top of the spare wheel carrier on the Red Terror and the autotune mounted to that.
    The autotune was earthed to the rear bumper and the leads were fed up through the grommet behind the panel in the rear that has the reversing light, blinker and brake lights.
    The antenna lead was run along the trim under the side window and the control lead was run under the trim at the top below the safari window.
    The power lead for the unit was run from the battery box and out through the front and then between the seats and up behind the trim and then along the cargo barrier to where the transceiver was mounted.
    The earth lead was run down to the floor and fixed to the seat belt bolt using braided copper lead from an old battery set up.
    The control head was mounted on the front of the cubby box as was the microphone.
    Thanks to Trog, all the VKS and RFDS channels were already installed so now its ready to go.
    Lets hope that Alvin and chipmunks will be replaced by "Good to hear you are having a good time out on the track". Now back to the manual to learn a few more functions. The Wagner had an on and and and off and a clarifier that never worked.
    Chenz
    I do not wish to be a member of any club that would have me as a member
    Former Owner of The Red Terror - 1992 Defender 200Tdi
    Edjitmobile - 2008 130 Defender
    Should that be 9323?
    If so, can you come and install mine?
    Melrose Park NSW
    Correct and I am afraid that you are on your own with your install
    Chenz
    May 2002
    Heathcote (in "The Shire")
    Who's been a busy boy ?
    Does it work ??
    Martyn
    Melrose Park NSW
    I can hear voices but have not really tried to transmit with all the interference.
    I will have the work out how to enter the new sellcall number in as his old one is still coming up. Maybe get a chance to head out of town when I get time to try and log in on VKS skeds.
    Chenz
    Glad to see all went well with the radio. Guess now you will be keen to get away for a bit ?
    Melrose Park NSW
    Quote Originally Posted by trog View Post
    Yeah thanks. Unfortunatly work will keep me busy for the next couple of months.
    Thanks again for the radio and all your help
    Vince
    Chenz
