                                                26th November 2012, 07:54 PM
			diff swap 85 county
					hi everyone
 im planning to remove my rear sals and install a maxi drive rear diff out of a 90 range rover.the rover diff has 4.11 centers, maxi locker, maxi axels, maxi drive flanges and diff housing has been braced.i know i need to fit a longer rear drive shaft because the rover diff is shorter.so im trying to find out how long to make the spacer for the rear drive shaft or if a later model defender (with out sals) drive shaft will fix my problem.
 any info would be good
 regards brett
                                                26th November 2012, 08:02 PM
					Crazy man.  Keep the salisbury & fit a locker in it. Keep the salisbury & fit a locker in it.
 I hope your going to change the front diff too.
 With a 4.1 in the back and a 3.54 in the front you will blow the center diff up in approximately 20 klm or 15 minutes, whichever comes first.
                                                26th November 2012, 08:19 PM
					hi going bush
 yes i also have front maxi to go in aswell with same ratio.ive had the rear maxi in a comp truck and it never failed me thats why i dont mind taking the sals out, unless i can find a maxi for a sals and a 4.11 c & p.
 regards brett
                                                26th November 2012, 09:20 PM
                                                #4
					Im pretty sure Bill at Great Basin Rovers will do Sals R&P. You could also see the range of Dana 60 R&B, as I belive these will fit with a little help...
 contact Ashcroft and ask them to make a Sals/D60 locker....the more that ask the better chance there is of it happening.
 M R Automotive may be able to supply a MD locker for your sals.
                                                26th November 2012, 09:27 PM
                                                #5
					just curious where did you originally get the 4.1 maxi front & rears.
 sounds just like the RR front & back ends I put together for my old 90 hybrid
 wonder where the rest of the car is, it had a 302W , C10 auto w lowstall & Nissan G60 xfer case held together with a Marks adaptor
