Results 1 to 6 of 6
Thread: TD 5 Turbo oil leak
    Oct 2012
    lethbridge
    TD 5 Turbo oil leak
    I have an oil leak at the junction of the oil pipe and the front of the turbo.
    I take it that a special gasket is required.
    Is there anything else or any nasties lurking there for me?
    Feb 2011
    Brunswick, Victoria
    Quote Originally Posted by worane View Post
    Yes.
    If it's the banjo fitting at the top: ADU6847L (x2) around $0.50 each
    If it's the drain at the bottom: PNT100030 (x1) around $2.00 each
    Genuine parts are probably double the above prices.
    It's been suggested you can reuse by annealing but given cost of new replacements I don't see that it's worth it.
    In terms of nasties - nothing that I'm aware of. The only advice I'd give is to make sure you torque to the correct settings given in RAVE.
    Paul
    Jan 2011
    Gippsland
    i did mine 2 months ago - easy peasy
    http://www.aulro.com/afvb/discovery-...t-weeping.html
    onebob
    Kingston, Tassie, OZ.
    The main thing to check is that the drain fitting flange is actually flat still. i have had to remove several of these drain pipes completely and reface them as they become warped and they continue leaking after a new gasket is fitted.
    JC
    Oct 2012
    lethbridge
    Sorry I have not made myself clear. It is the pipe IN FRONT of the turbo which runs down to the underside of the engine. It looks like it may supply oil lube / cooling to the front turbo bearing.
    Regards Nick.
    Last edited by OffTrack; 14th December 2012 at 09:40 PM. Reason: Same post in two threads merged
    Sorry I have not made myself clear. It is the pipe IN FRONT of the turbo which runs down to the underside of the engine. It looks like it may supply oil lube / cooling to the front turbo bearing....
    It is a flat flange with two bolts holding the parts together( with a gasket between)
    Regards Nick.
    That is the one I was talking about. 2 bolt flange under the turbo and drains back into the block.
    JC
