Page 1 of 8 123 ... LastLast
Results 1 to 10 of 78
Thread: Holden Motor Question
    Mar 2012
    Porongurup Western Australia
    Hi all, I was wondering about the 253 V8 into a Series Landy. I've heard of a few being put in and for a V8 they don't have a huge amount of grunt and I know the series box wouldn't like it a huge amount if you hammer it constantly but it's just a farm ute so it won't be under any huge acceleration but the 6 cyl holden is quite common and the 202 if tuned would probably have the same figures as a stock 253 so it may hold up if driven nicely. Any ideas would be great.
    Invermay Tasmania
    Its proberly on the same power as the rover v8 but with more torque
    Adam
    Mar 2012
    It probably is the same power as the 3.5 but the torque as you mentioned is the difference, how hard is it to get an adapter plate to make the series box to attach to the 253. I've heard of a few but they were a while ago. The 253 is similar to the Ford 250 motor for size power and torque probably but you can't beat the sound of a V8. The 250 would be my next choice and then the 202 not including all the valiant motors.
    Narre Warren South
    Just checked out Marks 4WD Adaptors and Dellow Automotive websites and not much in the way of Series adaptors (probably not enough demand now).
    Dellow still list Holden 6, Ford 6 and Toyota B diesel.
    http://dellowconversions.com.au/imag...Automotive.pdf
    They were helpful when I approached them about my C240 Isuzu conversion they made back in the 80's. Contact them and see if they made an adaptor and whether they still have any in stock. They claim 95% of replacement parts for their kits (since 1964) are available.
    History here with an mention of Land Rover conversions. Dellow Conversions
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Mar 2012
    Thanks for that gromit, I'm thinking that it would be easier just to put a 202 in it cause I know where to get adapters for it but a 253 or even a 3.5 would be great but they aren't easy to fit from what I've seen. A 250 would be good as well but again it's not a V8. My 2.25 is starting to smoke every time I start it know and it's using a little oil so it probably hasn't got long and it would probably be cheaper to drop another motor in it.
    Invermay Tasmania
    3.5 is an easy mod check out some of the uk web sites
    Adam
    Mar 2012
    Quote Originally Posted by agrojnr View Post
    Adam
    I like the 3.5 V8 cause I have one in my 100" but I don't know if it would be easier to fit a 3.5 or a 253. They both have the same sort of figures and an old 3.5 or 253 probably don't have a huge amount of grunt anymore and I've heard that a Series IIA box can handle up to 120HP at the max and I don't think a stock 253 had that out the factory. The main problem is finding an adapter plate thats cheap enough to make the conversion worth it cause I don't really want to spend $400 on a plate and then another $200 on an engine. I've only seen a few 3.5 kits on the net but they're about $700.
    Mar 2012
    If anyone has any info on fitting a 3.5 V8 to a IIA please let me know, the only problem with a V8 is the gearbox, an old Rover V8 wouldn't have much grunt and I wouldn't be upgrading it for anymore power just make it run well if I went through with it. A 202 and a 3.5 would probably be similar.
    Mar 2012
    Finally decided that if I'm going to do a engine swap its going to be a Rover V8 or a Ford 250.
    Crafers West South Australia
    Probably a bit far away from you but there was a complete crossflow motor and Nissan box on ebay, no bidders:
    landrover ford crossflow nissan gearbox | eBay
