 Member
						Member
						hi guys
i have 1995 defender 300tdi which is running hot:
new thermosat and radiater and installed vdo gauge and matching sender runs at 100 deg on 30 deg day
no leaks holds pressure and does not boil, heater works ok
therostat housing hot
when run at idle doesnt get to temp bottom hose is hotter than top and radiator cool to touch, circulation problem?
have bled air out of water alarm on top thermo housing
, what next?
thanks
 Master
						Master
						viscous coupling for the fan ?
I had an aftermarket one that wasn't locking up soon enough.
Made the temperature rise.
A quick manipulation of the spring on the front and has been fine for several years.
If your not getting the loud fan roaring noise, then the viscous is most likely failing.
'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
If the top hose is cold and bottom is hot seems a bit odd the hot water leaves the thermostat housing and the cool water comes out the bottom maybe wrong thermostat or crook water pump seems odd tho that it does not cook at idle.
 Wizard
						Wizard
						hi,run engine till hot ,turn off , if you can turn fan blades by hand its you viscuse coupling not working ,when hot it should be locked on and shoud be tight therefore pulling air through your radiator.it sounds like its not spining .
 TopicToaster
						TopicToaster
						radiator? has it ever been cleaned? have you always run the correct coolant?
if you don't get the roar of the fan when it comes on then it is suspect!
As pointed out below, the radiator is new. Hmmm!
Last edited by slug_burner; 16th December 2012 at 07:16 PM. Reason: pointed out that radiator is new.
my 300tdi Defender did exactly the same thing. Turns out the radiator was largely blocked. Had the tanks removed and the core rodded and now perfect.
I'd have said radiator as well but johnodef mentions a new radiator in the first post. Possibly the aircon condenser could be blocked? I've done 2 viscous fan hubs over the last 10 years, both still turn by hand when hot, both are genuine Rover. Did each as a (expensive) precaution when the problem was a blocked radiator.
 Member
						Member
						thanks guys
new radiator and air con condenser removed, will take it for a run and check the viscous coupling
do water pumps actually fail to pump?
could there be an air lock?
i have bled air out of the alarm in the thermo housing.
With the new radiator everything should be good, --- But !! --- if the cooling system hasn't been flushed properly at the change over to the new radiator, rubbish that is still loose in the galley's can still plug the tubes in the top of the core, the flow then bypasses most of the core, going direct to the outlet via the huge bleed hole in that baffle plate half way down in the tank, ( I am currently experimenting with a radiator that has the tropical mod done, where that hole has been reduced down to 3 mm ).
The symptoms of just this problem, is that the engine heats slowly on a constant pull and is slow to lose it's heat when stopping to cool it down. This cooling time can be sped up by spraying water around the radiator tanks and the top of the engine, I have used one of those pressurised 5 Litre garden spray filled with water to do this and it was APITA to do each time it got hot, but it worked enough to get me home.
Borrow a good viscous coupling and give that a try first.and air con condenser removed, will take it for a run and check the viscous coupling
Yes, I have seen a impeller totally rusted out and on another, the impeller was spinning on the water pump shaft.do water pumps actually fail to pump?
I had a batch of bad bearings in some of the cheap pumps ( $ 30 each approx plus freight ), I suggest that you buy a ' QH ' brand or better to save yourself some grief.
When you change the water pump do the 'P' gasket as well, as when the tension is released off the bolts the housing can spring a fraction breaking the seal on that gasket.
Try this, the bleed pipe from the top of the thermostat housing can block at the plastic venturi, pull the hose off the thermostat and blow through the air bleed pipe while squeezing the pipe shut that goes into the top of the radiator first and then squeeze the pipe shut that goes to the expansion tank, you should be able to blow easily through both pipes. If it is blocked a 3 mm drill bit can be used clean out the ports of the venturi.could there be an air lock?
Interesting, I installed my alarm sensor into the top of the radiator tank as per the instructions, it seems to work well there and the wiring is better protected running down and along in front of the radiator.have bled air out of the alarm in the thermo housing.
Pull your thermostat, pop it into some hot water on the stove, it should open steady and be fully open just before the water boils ( 88°).
Just as important, check that when the thermostat is cool that the valve is fully closed and there is no light coming past it's sealing face.
I use in a 300TDi, a 50 /50 mix of green coolant changed once every two years.
