Results 1 to 8 of 8
Thread: Suspension raising slowly
    Got this message today. I admit I was putting it into Llams special mode high at the time but only once, I wasn't messing around raising and lowering repeatedly.
    Is this a bad sign?
    No.
    The handbook specifies that this is not a Fault message but an advisory message.
    Just means the air bottle has been exhausted and the car is being raised on the air compressor alone - alternatively your air compressor may be hot from playing around with LLAMS too much and is having a rest.
    It is important with LLAMS not to be going up and down a lot - select what height you need and leave it there.
    If you continually get the the message then by all means suspect a fault but the occasional message is quite OK.
    Thanks Garry, that's a relief, I have seen all the compressor failures here and was a bit worried for a Minute that it was a sign mine was on the way out.
    Sydney, Australia
    Could be a good idea to sieve and dry the compressor dryer beads?
    Brisbane,some of the time.
    Quote Originally Posted by CaverD3 View Post
    How is this done,is it relatively easy?
    X 2
    SBD4's Avatar
    SBD4 is offline A Keeper of the TGO Gold Subscriber
    Dec 2011
    Bundeena
    Quote Originally Posted by AnD3rew View Post
    X 2
    Look at these threads:
    http://www.aulro.com/afvb/d3-d4-rrs/...ompressor.html
    http://www.aulro.com/afvb/d3-d4-rrs/...or-repair.html
    Sean
    Andrew I have had that message a few times and mainly playing around with LLAMS. The system when charged will raise from access to offroad +50 and back probably twice before it runs out of puff. When raising one step (say the equivalent of onroad to offroad) then I just do it but when raising over a greater range I wait until I hear the air compressor is stopped as that should mean the airtank is full - this is usually enough to make any height changes that are required and does not stress the compressor.
    It is my view that then compressors while probably a little small are up to the task if common sense is used with the height. I used to lower to access everytime I stopped to get in and out - raise it from offroad to +50 at the sign of any rough stuff - I no longer do. I run around at -20 and when offroad I stay at onroad +50 (or +30 or whatever it is for better roads) and try to resist the use of offroad + unless absolutely necessary - as it saves the air compressor. I believe the majority of compressor failures are caused by clogged desiccant making the compressor work hard and over heat leading to failure. I am not sure why Landrover didn't build the things with a serviceable desiccant canister in the the air intake hose and it is replaced say every 48,000km in normal use. I think that their logic was that as the air intake is in the cabin the air compressor would be sucking in dehumidified are from the cabin where the A/C system has taken the moisture from the air - the reality is somewhat different.
    My car has now covered 72,000km and the compressor is still working but at that Kms I assume the desiccant is starting to get full of water. I think I will also de-humidify my desiccant on the basis of information provided on here.
