Results 1 to 2 of 2
Thread: Interior part numbers.........
    Mackay, QLD
    Hi there,
    Well, Santa came a little early for me this year in the way of a "mechless" Fusion radio, which I duly fitted while I was down in Burrum Heads recently. It is not a bad little piece of kit as it no longer has the CD player, and draws all my music from my iPhone.
    Anyways, while I was changing it over I happened to establish that there are several parts broken in the dash area which I need to replace. These are -
    1. The A/C vent which and shroud which you can easily see in the attached picture.
    2. The black plastic shroud immediately surrounds the car stereo itself (you can see how the bottom of it protrudes from the centre area); and
    3. The black centre piece which houses all of the various buttons, including the radio it self.
    I am aware that Raptor Engineering does a centre dash, however this is predominantly for upgrading the TDi.
    If any of you can assist in giving me the part numbers, or directions to a schematic of the interior where I can get the part numbers, it would be superb. Or even if you've got a recommendation for suitable replacement parts, I am all ears.
    Merry Christmas to all!
    Dec 2010
    if you are after genuine LR parts and your defender is later than 1987 , than
    you can look up all part number on this website:
    Çàï÷àñòè äëÿ Land Rover
    it is in russian , but just click on " spare parts list" at the bottom of opening page and than select your defender model on left
    everything apart from opening page is in english
