Hope you have the cooling side of it sorted out![]()
Finally got the 130 defender finished. Now she runs a 6.5 chevy diesel with a lt95 gearbox with the .996 transfer gears.
Had a fer probs along the way but hey 2 years off the road and well worth the time and effort.
Cheers......Brian
1985 110 V8 County
Hope the full write up goes into the good oil.
2011 Discovery 4 TDV6
2009 DRZ400E Suzuki
2003 WK Holden Statesman
Departed
98 Ducati 900SS Gone & Missed
Facta Non Verba
43 degree day in southern cross and took it out to test and so far no probs cooling. I have a custom 3 row full alloy radiator in wb statesman configuration with a set of bf ford thermo fans. Also an oil cooler as I think these engines have too smaller sump and the oil heats up too much. Haven't put the air con back together yet but when I do I will run a separate condenser/fan setup like the npr isuzu's do.
It seems you've researched it, hope it goes well for you. Mine was a pos, only thing I miss about that engine was the sound![]()
i was down at albany one summer and a guy came into the park with a toyota with one of those motors in it , it had only been in there for 3 months and the fuel pump packed up , dont know if that could be a problem or not for you
Fuel pump is just a fuel pump, injector pump is a different story. I ran a Mallory electric fuel pump with a regulator on it, think it was set at 9psi?????????
reliability has not been their strong points. Time will tell.
Hey see how you go. Horrible engine, under powered, thirsty, heavy, and un reliable. But you do here of the odd one that is trouble free. Sound very cool though.
Will keep an eye out for it when I pass through the Cross. I'm up & down the road regualrly (was stuck there for a couple of hours the other day when they had the rollover on the highway - until I took off for Forrestania). Will be back through there next Wednesday on the way back down to work.
I used to have a Ford F100 with the Chev V8 diesel in it. No real problems after sorting out an initial issue with rocker arms snapping off - it's still kicking around Kalgoorlie at the moment, though I don't know what engine is in it now. Canopy has gone and there's a big gas tank in the back - don't know if he's still got the Chev V8 and running diesel / gas or has put a petrol V8 back into it and running it on gas. The tank that's in there is way bigger than you would need for diesel / gas.
Cheers .........
BMKAL
