Results 1 to 9 of 9
Thread: self recovery of rolled vehicle with winch
    Jul 2008
    Ballarat, Victoria
    is it possible to self recover a vehicle using its own winch?
    i'm not talking about a massive rollover, just if it was laid on its side while off roading or something similar
    if it is possible, what is the procedure for it be carried out safely?
    Yeah it is if you have a snatch block and tree ,better if you have two
    95 300 Tdi Defender 90
    99 300 Tdi Defender 110
    92 Discovery 200tdi
    50 Series 1 80
    50 Series 1 80
    www.reads4x4.com
    99.87 MB
    [ame="http://www.youtube.com/watch?v=8rOEsWYuMRA"]Land Rover rollover self recovery - YouTube[/ame]
    Slunnie
    Thats one of those how long is a piece of string type questions and the limiting factors are typically how much gear you have, how good your anchor points are, how the vehicle is positioned how quickly and cleverly you can rig recovery sets.
    Everything is working against you if the vehicle is on its side an electric winch might be good for one good pull depending on the battery type and configuration and a hydraulic/pto one will be nearly useless to you unless you have an auxiliary power unit for it that will function.
    Nanny state UK...
    ...another good reason to carry a hand winch, instead of a vehicle mounted one.
    M
    Yinnar South, Vic
    Yes, still never needed a hand winch
    Quote Originally Posted by rovercare View Post
    kinda like condoms, you dont want to need one but its best to have it and not need it than to not have one and need it.
    Oct 2003
    Godwin Beach Qld
    Yup! best way to waterproof a weapon barrel
    Warragul, Victoria
    Never forgetting to restrain the casualty so that when it is hopefully, eventually, righted is number 1 on the list of things to do.
