Results 1 to 10 of 13
Thread: Box Trailer Paint
    Box Trailer Paint
    My box trailer needs a new coat of paint. Like most smaller box trailers it has been painted in a "hammer" paint and I would like to do the same.
    I am familiar with Hammerite Brand which is a a great paint and UV stabilised but is hard to find. Hardware stores like Bunnings sell a Hammer paint (Hammertone) but this is not good for outdoor use as it breaks down in UV.
    So does anyone know what "Hammer" paint the trailer builders use and where do you get it.
    Sep 2009
    Northern Rivers
    good question! I too would very much like to know this, I will look around and see what I can find.
    -Jarrod.
    They generally get the cheapest they can for bulk, I have found the best colour for longevity is charcoal, blue and red fade quickly in the sun. Townsville Is a good testing ground as the sun will nail anything that's left unattended.
    I have repainted a few trailers and all the hammer tone needs is a good clean, scrape off the surface rust and spray away, the stuff sticks like **** to a blanket
    Series 11A ex Air Force
    1995 ES Discovery TDI
    RIP 2006 Discovery 3
    RIP 2004 V8 Discovery
    RIP 95 Discovery TDI
    RIP 1999 Freelander
    RIP 1978 EX Army FFR
    Wattyl epoxy metal paint if applied in multiple light coats and left to cure for a few days in between coats, will build up into a very hard surface. Takes a while but is worth the effort.
    South East Tasmania
    After building several steel hull yachts my recommendation for a near life time paint work will be sandblasting the trailer and then apply a undercoat using POR 15 paint.
    Once the coat is tacky then apply 2 coats of Wattyl paint.
    The Watty paint will protect the POR15 undercoat wich it is not UV resistant and the POR15 will protect the metal surface against the friction made by shovels, cargo, etc.
    It is very important to apply the first coat over the POR15 coat when the undercoat is not dry. Once POR15 is dry nothing stick on it.
    You do the job once and is done for ever. Only occasional touch ups will be required for the top coat.
    If you do not like to have to touch up the top coat, then do the top coats with POR 15 for marine decks and that is the end of your slavery
    Thanks for the alternative suggestions but I am after Hammerite - if anyone knows where I can buy it I would appreciate it. The local stockists listed on the Hammerite website have never heard of it and of course do not list it.
    I can contact Hammerite next week but was hooping to do the painting this weekend.
    Mar 2010
    Wattyl Killrust is available in Hammertone finish!
    Quote Originally Posted by Owl View Post
    I have used it before and on initial use seemed great - seemed to degrade after about 6 months so may not be UV stable.
    May 2008
    Rockhampton
    how did you go with this my trailer is up for a paint job now
    I could not get Hammertone so just used the cheap hammer finish spray paint from supercheap. Is not great paint.
    I painted the trailer and then sold it that week so I have no idea how it is holding up.
